iPhone 11/11 Pro
htngwilliam
Why u worry if you are not flipping. With official apple store, no chance to flip liao. They may have anticipated ppl usually hold on to stocks and flip
*adiBOY
Does it matter? They need to say its good.
When something it's bad, they can freely say it just like the XS. Saying negative things will not affect the chance of getting the next iPhone for review.
Apple doesn't care what you comment about the phone. They appreciate honest opinions. You can bash the phone all you want but you can still get the next iPhone for review if your channel has a certain number of followers.
metamofia89
Hope some you guys can chip in with the battery life for the Pro/Pro Max in the coming days. :)
IceX
so i got a new 11 pro max and decided to erase all contents and settings on my current iphone 8 plus before switching my sim card over.
On my new phone, i just realised my sim card don't have all my contacts.
any solutions?
i_am_fatimah
any solutions?
Contacts supposed to sync with your iCloud right
ragnarok95
Senior Moderator
Senior Moderator
any solutions?
If you got sync to your icloud then it will be there.
szeli
any solutions?
u never backup?
kokfann
Login to your iCloud with your pc/MAC and check whether the contacts are there or not. If yes, then it’s maybe due to ur phone setting. Is contact turn on/off at the settings->iCloud?
tbh i nv recall got a not haha..thought i did saved to my sim
Marcus19
Unless want to sell phone before getting new one, should not erase first :o
Much easier to transfer between iPhones. Just switch on new phone nearby your existing, will be guided to transfer data from old iPhone
any solutions?
deathst
disastrous
Is it me or haptics become much weaker? Apple Pay vibration feedback used to be quite strong.. now just a 0.5 sec weak vibration
