iPhone 11/11 Pro
ragnarok95
Senior Moderator
Senior Moderator
What’s the point of 5G when the telco might not have the infra in place to support it.
Just like esim
M1 already got esim. Quite sure the other 2 also have esim, just waiting when to launch only.
thenakedshades
Yea! First set is telco. Hahah you have a spare X or Xs with you? Try putting it next to the Pro with the same settings (Truetone off, auto brightness off, night shift off and colour filter off) not sure, but mine seems a little off as compared to the Apple Store demo set.
yup. your first set is telco set?
so far mine i never see any tint though, or maybe my eye cant see :s13:
KeYoKe
fade_white
Does anyone know how long it takes to fully charge an iphone 11 pro on a 7.5w wireless charger?
deathst
Depends on what percentage you start at?
No one really measures wireless but here
radzkal
Need to check with you guys about two things:
1. I tried to manually set dns but pressing save does not save the dns setting. Happening to any of you?
2. Is it normal for app store to keep asking me to enter icloud password before downloading new app? It is supposed to use Face ID, right?
*adiBOY
1. No. Mine works fine.
2. Did you set purchase from AppStore to use Face ID?
thisisnotme1212
Noticed a huge speck of dust or lint or something underneath the camera glass.
Just replaced my 11 pro max today.
Remember check inside guys... now very paranoid Liao haha. Finally all settled :s22:
chiu all using ur pro max with cover or withouts? :(
needs to finds a good covers :(
https://www.gsmarena.com/mate_30_pro_vs_iphone_11_pro_vs_galaxy_note10_camera_compare-news-39381.php
Sent from Rem Is Best Waifu using GAGT
