iPhone 11/11 Pro
*adiBOY
Aikon
Need to check with you guys about two things:
1. I tried to manually set dns but pressing save does not save the dns setting. Happening to any of you?
2. Is it normal for app store to keep asking me to enter icloud password before downloading new app? It is supposed to use Face ID, right?
With regard to DNS not sticking, this only happens when I switch iPhones/iPads and restore from backup.
Resetting all network settings fixes it.
aztech44
Anyone encounter you plugged the cable but phone didn’t charge? Need to unplug and plug multiples times up to 3 times to get it charge, facing this with iphone 11
1 time plug onto iphone 8 no issue.. i tried changing different cable yet still the same.
Carnage
I thought it was my cable problem.
Celibrium
Hi does anyone have the issue of being unable to search for older messages on whatsapp even though everything is there? Restored from backup from my old iphone 8 to my new pro max, messages are all there but when i search, nothing pops up
Levitating
Same cannot search message after backup
tec_geek
darkkey
Yes I encountered the same issue with original cable and Anker cables.
Some cables are fine while others does not charger. All cables charge fine in iPhone XS Max.
aztech44
So you solve the issue by getting a new cable? Dont understand why current iphone 11 take multiple times to charge it while iphone 8 take it 1 time to charge with the same cable and same charger
mikeeeey
Happened to me
Waited for reindexing to finish also cannot
In the end just have to uninstall whatsapp and reinstall again. All will be okay after that
darkkey
I just tried a different cable and it worked.
Looks like a hit and miss with certain cables.
Have not charged since I updated it to 13.1.2 to see if the problem exists.
