Jirachi
- Jan 17, 2010
Why ugly? Just the back got 3 cameras so big difference meh
Chances are, one is less likely to see the back than the front.
Must compare side by side. Your screen is only 6.1 to 6.5 inch. 720p vs 1080 vs 4k, I doubt u can tell the differencr
Where can i get it at this price?
This is ********. Same like when people say eye csnnot tell difference of 30hz 60hz 90hz 120hz. Take a good look at iPad pro
I guess it largely depends on whether you are using this phone as your main camera device. If it is, I would say the IP11 would be a better choice due to it's dual wide angle lens and night mode support. You can always wait for a while before getting it at MS/RWM as I'm sure the price of IP11 will also drop by then.
Also thinking between 11 and 11 Pro
Using as main device for everything including photos
Simple. Unless you really need that Tele lens, you should go for the iPhone 11.
In everyday use, both phones are as good. Apple has the best LCD display and you won’t notice a difference in that lower resolution display unless you compare both phones side by side.
Strengths:
11 will have wide angle lens camera
11 will have A13 bionic chip
11 will be cheaper in price
XS Max has better resolution OLED screen
XS has 2X optical zoom lens
Weakness:
11 screen is lower resolution LCD
11 doesn't have 2x optical zoom
XS Max will still be more expensive
XS Max won't have wide angle lens
XS Max will be using older processor which is less battery efficient and less powerful
Sent from Samsung SM-N975F using GAGT
Apple website says iPhone 11 does have 2x optical zoom. Correct me if I'm wrong
Yeah it's 2x if you count the wide angle lens to normal lens. It's effectively 2x zoomApple website says iPhone 11 does have 2x optical zoom. Correct me if I'm wrong
