IPhone 11 or XS Max
chanbri
But I can't get used to the XR/11 LCD screen. OLED is just so good on XS Max. Its way brighter too. That's why it's battery life suffers.
Sent from Samsung SM-N975F using GAGT
szeli
I have done side by side comparisons in e  Store. resolution wise both look similar to me. only big difference is e brightness. OLED is a lot brighter. of course it's ymmv as always.
szeli
Apple website says iPhone 11 does have 2x optical zoom. Correct me if I'm wrong
for iPhone 11 it says 2x optical zoom out (cos ultra wide angle)
iPhone 11 Pro it says 2x optical zoom in and out (cos tele + ultra wide angle)
it makes sense now.
weelit
For me it will be iPhone 11 no brainer. I will get iPhone 11 even it’s slightly pricier than xsmax.
Red Nails
Simple. Unless you really need that Tele lens, you should go for the iPhone 11.
In everyday use, both phones are as good. Apple has the best LCD display and you won’t notice a difference in that lower resolution display unless you compare both phones side by side.
Hahaha using X now
Tbh i can tell the diff la :o
metamofia89
I used to play down the observational difference between an OLED and LCD panel until recently when I got to play around a Note 10.
The deepness of the black colour is very obvious. I’ll definitely enjoy the stock Earth wallpaper on my next OLED iPhone.
jetblack
it makes sense now.
i guess that makes effectively 4x optical zoom for 11 pro
*adiBOY
Night mode - hope there’s a substitute for this
Most consumer will just use the stock night mode which is convenient and easy to use. Only tech enthusiasts will try to use different softwares.
You can look out for Halide camera app. Probably the best camera app out there.
Jxoppa
I can tell the difference without putting both phones side by side. That is how sharp and observant my eyes are.
hyperpower
wah then buy iphone 11 quite worth it considering it almost got all the new features
