iPhone 18Pro/Pro Max Discussions
What colors did you choose for 18 pro?
  • Burgundy
    Votes: 39 39.8%
  • Glacier
    Votes: 25 25.5%
  • Black
    Votes: 24 24.5%
  • Silver
    Votes: 10 10.2%
  • Total voters
    98
kuma-mon
the 18 pro series can last more than a day given its battery capacity which is more than sufficient. that's why even with eSIM model the extra battery life will not make such significant difference than before.
That’s what they said with 17pm until Apple release ios update and kill the battery
Fellowes
Price comparison of last year Pro models, in SGD.
Storage17 Pro17 Pro Max18 Pro18 Pro MaxDuo
256GB$1,749$1,899$1,899$2,099$3,099
512GB$2,049$2,199$2,199$2,399$3,399
1TB$2,349$2,499$2,799$2,999$3,999
2TB$3,099$3,699$3,899$4,899
Even the advantage of Japanese Yen gap is close, the difference is about $100 ~ $150 only but you get the pure eSIM variant with larger battery.
Lucky I bought 17 Pro 512GB at SGD$1820 last year in Japan, so not changing this year. Save money!
Rubick
Based on dimensions 17 Pro series cases are likely cross compatible with 18 Pro series.
Yea, before launch, ppl got say pro and pro max case reusable.
Seems like I can reuse my rebel phone case from 17pm
kashix
Unlikely re-usable, cause a lot of case makers list separately for 17 Pro/ Pro Max and 18 Pro/ Pro Max
Rubick
Wait come le will know. Maybe list separately so ppl will just buy haha.
I will likely get a burgundy color case also 🤣
Kyubi
Some case maker do change their info to /18 pro max. That’s why I am confused.. looks similar when I compare dimension and spec.. tempered glass also same
abrams75
18PM since I yearly upgrade. No doubt the difference is more of internally then physically as a whole but being using for so long already use to it. Duo is just too expensive
