iPhone 18Pro/Pro Max Discussions
What colors did you choose for 18 pro?
  • Burgundy
    Votes: 39 39.8%
  • Glacier
    Votes: 25 25.5%
  • Black
    Votes: 24 24.5%
  • Silver
    Votes: 10 10.2%
  • Total voters
    98
Charlie_Zhan
I’m thinking of getting the iPhone duo when I am in Shanghai. Does anyone knows if the warrenty is for local or does it cover internationally. Did anyone bought their iPhone in China before. Any potential issues soft or hardware issues ?
There might be delay of launch in China due to it being a eSIM only device and regulatory approval is required. CN model has an additional WLAN & Cellular settings which you will have to explicitly set which application to allow either network access. It does not support FaceTime Audio as well.
taking china's iphone air for reference, no facetime, no AI, only can store 2 e-sims in the phone, overseas esims can work while you are overseas, but it gets disable the moment to travel back into china.
certain emojis are not available on the china models as well.. 🤭
kashix
I rmb for eSIM model, their eSIM only support certain China Carrier, you might have problem using eSIM out of China. Seems to be okay ~
When travelling outside of China mainland, you can activate an eSIM from a local carrier on your eSIM-supported iPhone purchased in China mainland. To do so, you must have location services enabled. eSIMs from non-China mainland network providers can’t be installed while located in China mainland.
Rubick
Spigen using same case for 17/18 pro and pro max liao.
Price all went up haha
kashix
Now got problem is the modem used in 18 Pro and 18 Pro Max are different. Singapore have C2 for 18 Pro, while 18 Pro Max likely is still using qualcomm solution. Not sure how the performance stack up.
MarketiPhone 18 ProiPhone 18 Pro Max
CanadaC2C2
BrazilC2C2
AustraliaC2C2
IndiaC2C2
ItalyC2unnamed
SwitzerlandC2unnamed
SwedenC2unnamed
UKC2unnamed
TurkeyC2unnamed
SingaporeC2unnamed
PhilippinesC2*unnamed
U.S.C2unnamed
Jirachi
CanadaC2C2
BrazilC2C2
AustraliaC2C2
IndiaC2C2
ItalyC2unnamed
SwedenC2unnamed
UKC2unnamed
TurkeyC2unnamed
SingaporeC2unnamed
U.S.C2unnamed
I really really hope the 18 Pro Max is C2 also. 17 Pro/Pro Max was still on the Qualcomm one
Charlie_Zhan
apple still has an ongoing contract with qualcomm, so it’s likely going to continue appearing on some models in their product line until the contract ends.
Charlie_Zhan
anyone realised there is no increase in the selling price for 18 pro 256gb and 512gb for our neighbour? still starts at rm5499 for the 256gb pro model.
Habrosus
Wow not getting pro or pro max ah. Like that need wait mar liao
Last year upgraded from 12PM as primary phone to 17PM. Not a fan of Pro coz didn't enjoy my 12P while using those 2. Air1 was too replaced 12P...
