- Dec 27, 2007
For those wondering how to check your display manufacturer...I forgotten how to check, can share the step again?? Thanks!
You can run sysdiagnose on your phone (press volume up, volume down, and lock button) all together for around a second. You will feel the phone vibrate.
Wait a couple of minutes and then go to Settings -> Privacy and Security -> Analytics and Improvements -> Analytics Data.
You will then scroll down and look for a file titled: sysdiagnose_XXXXXXXX.
You will click on that file and then dick the arrow in the upper right hand corner and scroll down and click “Save to Files” Once it is saved you will go into your files and click the file to unpack it.
Within the folder that is unpacked you will click on the folder “ioreg” and then click the file “IODeviceTree”.
You will then use the magnifying search glass in the bottom right hand corner to search “raw-panel”. It will then give you a serial number.
I have an LG display which has the beginning letters of GH3.
GVC is the best of the LG panels but not as good as Samsung’s best which is the G9N.
The top 3 panels are:
• Samsung G9N • Samsung G9Q • LG GVC
The worst panel is LG GH3.
