iPhone 5 Lightning Cable
chester121
Am using braided lightning cables cos they're more durable than the apple ones. But to each his own. :)
chenaz
My iPhone 5 cable still with me. Only the part near the adapter can see the physical wire inside. Last time Donnoe how to take care thrn anyhow pull
LesterQ
Yup I agree; anything wrong with the cable within the 1 yr warranty period, just call Apple, they'll send you a replacement cable & you just return the faulty one.
How true is this? You have personal experience or?
http://www.apple.com/sg/shop/question/answers/product/MD818AM/A/is-there-a-warranty-on-lightning-cables-for-iphones/QDYDT2AT2T9HJ4FJP
Wear and tear damage not covered...
hawkz02
I'm using verbatim 30cm one and quite good.
All MFI one will be ard this price as it is controlled price .
Do you have experience with shorter cables?
How come the anker is $15 for a 0.3cm cable :O haha
paul02
Just use Verbatim's lightning cables. Warranty and RMA process is quick and easy.
Tried and tested. Trust me.
revogsx
i tried many cheap lightning cable before. they will die eventually.
so now I use just branded ones. my favorite is the verbatim one. 2yrs warranty and is very durable too
ekardo
Actually you can go sim lim to anyhow buy a lightning cable. it worked too :s13:
works at first..then over months..will failed to charge...
so far, for my experience with so many brands (remax, pisen, etc) only original and verbatim is good..
duhduhduh
Buy the adaptor, then use the normal android cables!!!
TRUST ME....
All the angmoduaki does that.
Its cheaper in the long term! Somemore can interchange the cables
