Just received my vinyl stickers from taobao
Finally product with the casing
Where did you buy the magsafe phone stand from?
taobao link https://detail.tmall.com/item.htm?i...oughtlist.suborder_itemtitle.1.66eb2e8dVy9OGSWhere did you buy the magsafe phone stand from?
Thank you !taobao link https://detail.tmall.com/item.htm?i...oughtlist.suborder_itemtitle.1.66eb2e8dVy9OGS
bought another NIllkin for standby.
this is not bad as it comes with the screen so no need paste SP. i threw away my privacy screen.
which sp are u using with spigen aramid?Nope currently using spigen aramid, cause mange to find font screen protector that fits so give up pitaka with their lousy front protector
I messaged the fella but no reply
Nilkin onewhich sp are u using with spigen aramid?
depending on how u drop ur phone..i think TG crack is a good thing.. it means it's protecting the impact from damaging the screen due to dropping.. if it doesnt crack then your real screen high chance will crack instead..Just got my Pitaka casing last night and within 30 mins i dropped my phone for the first time in a week of owning the Duo!
To my horror, the Pitaka screen protector cracked. The weeklong protector i bought as an interim during the 1 week wait for Pitaka, was so much durable and good. Anyone else face this problem?
Anyone modified their Pitaka casing by removing its screen protector? Did the front case still fit?
How did the drop occur? Slipped out from your hands while opening the Duo? Foldables in general try not to drop. For fear the hinge mechanism will be damaged. Thank God your screen is fine.Just got my Pitaka casing last night and within 30 mins i dropped my phone for the first time in a week of owning the Duo!
I think there’s quite a lot of casing, just that most are damn shittyHow did the drop occur? Slipped out from your hands while opening the Duo? Foldables in general try not to drop. For fear the hinge mechanism will be damaged. Thank God your screen is fine.
I’m using Pitaka also for my Duo. But back casing only. I’m a fan of Pitaka haha.
Duo cases is really limited. Hope Pitaka make more design for the Duo, best is with hinge+back design. Since front I’m using full screen sp.
Benks just created a aramid fiber plus hinge protection case - might be the best of both worldsHow did the drop occur? Slipped out from your hands while opening the Duo? Foldables in general try not to drop. For fear the hinge mechanism will be damaged. Thank God your screen is fine.
Read the tb user reviews first before hooting ya, if u can accept the cut out alignments.Benks just created a aramid fiber plus hinge protection case - might be the best of both worlds
