Iphone Duo cases/accessories
NeonX
Popsocket low profile is similar to ohsnap grip. But I like ohsnap grip stand as it can be use as a phone stand at more angle than popsocket and ohsnap grip.
*ohsnap grip stand and ohsnap grip are 2 different product.
Grip stand got a few reports of it breaking off though
PetPet
Moderator
Moderator
:s22: :s13: none of the screen protectors i've gotten works. They all lift at the edge and I'm not using a case.
will be giving smartdevil a try and report back.
argentinafa
Can try ugreen AR. Full screen. Pg2 Deceased bro used before. Kashix bought for me and I’m having it as a good standby down the road.
My current AR glass is bought from xgear at waterway pt. Good thing about pasting at shop is they’ll help you solve any lifting, dust under sp issues so that you don’t need to deal your own self. They’ll change glass if existing one they’re pasting is causing lifting on the spot.
PetPet
Moderator
Moderator
yes i saw the ugreen AR post after i made the purchase on TB :s13:
will give retail stores a try if my third attempt fails. thanks for the suggestions :D
Deceased
Sometimes the edges not sticking issue can be fixed by persistently pressing and rubbing it.
Don’t give up lol👍🏻
Crayon Shinchan
Using the speck case, so far tempered glass hit and miss.
Using the smartdevil TG. Ok for my wife Duo. But mine keep have lifting. Think positioning need to be very very precise.
Anyone recommendations of other TG from Taobao?
oric1
My ESR case and screen protector arrived yesterday, exactly two months after I placed the order.
I asked ESR why it took so long, and they explained that due to the special design of the foldable device, their R&D team needed to get hold of the actual device and conduct repeated tests on their products to ensure the best user experience before shipping them to customers.
The Corning tempered glass screen protector was very easy to install as it came with an UltraFit installation tray.
The case has a 180° rotating stand at the camera area. The hinge cover is magnetic.
So far, I'm very happy with it. It feels solid and reassuring in the hand.
AGP™
nice. any spare to sell?
