Iphone Duo cases/accessories
argentinafa
i just bought a screen protector from a retail store which dont cover the whole screen of my iphone duo. why is it ? any recommendations?
If you’re using a front case too, then this non full screen sp of yours is built this way to accommodate the front case circumference. If you want quick solution, best is walk around shopping malls and ask around. Nex top lvl alot of those kiosk selling sp. xgear @ waterway pt is also good
memoriess
ahhh. thanks. is there any full screen sp that can support the front case?
oric1
He dropped on the tiled flooring with only front and back protection (no hinge protection).
argentinafa
Usually have to let go of one element. Full screen sp=front case wouldn’t fit. Semi-full/non-full should be Torras, dbrand. Amazingthing is the smallest sp.
Best is bring your case to the shop. Choose your preferred sp (privacy, clear, AR, Matt). Coz those guys paste over a hundred of sp for Duo already so they know best. If on the spot your front case cause any lifting or can’t fit the sp, at least you wouldn’t be charge for the sp being pasted.
argentinafa
Pitaka having BF sale at their official website. 20% off. Those who like to use back casing only, it’s a good time to get it. Really slim profile case to have without having to compromise on the already wide aspect of Duo.
harocarlos
My ESR case and screen protector arrived yesterday, exactly two months after I placed the order.
I asked ESR why it took so long, and they explained that due to the special design of the foldable device, their R&D team needed to get hold of the actual device and conduct repeated tests on their products to ensure the best user experience before shipping them to customers.
The Corning tempered glass screen protector was very easy to install as it came with an UltraFit installation tray.
The case has a 180° rotating stand at the camera area. The hinge cover is magnetic.
So far, I'm very happy with it. It feels solid and reassuring in the hand.
is the raised lip on the front very thick? I suppose its so that the duo is balanced when opened and lying flat due to the thicker rear camera island
Deceased
Other than speck? Anyone using any other clear transparent case to recommend? With hinge protection
I tried benks and power support, both have the issue of clipping the side front border when folding the phone.
specks is the only one i tried that doesn’t have this issue. I have a Popsocket clear case arriving next week and I’ll update if it’s yay or nay.
