Iphone Duo cases/accessories
Deceased
This kind of addon reliable not ah? feels a bit flimsy
There’s adhesive on the hinge cover and the back case will also prevent it from coming off based on videos. Check post #177 to visualise how it works.
Only one way to find out if it’s good.
argentinafa
took you recommendation to xgear. the staff is really proficient.
unfortunately, i think my duo is one of a kind :s13:
it was perfect at the store. halfway home, and it started lifting again.
You can go back there to ask them change sp bro. They will uds it might be their sp adhesive issue and replace for you foc. Maybe just after pasting, linger in the mall longer for lunch etc to let the sp settle down to see if it lifts again.
Oh ya btw, how come this thread cannot be found in the iPhone chat room already
Deceased
Slimmer than specks but it’s 2 piece case and front has adhesives which is quite visible and not very aesthetic on a clear case (ocd wouldn’t like it).
NeonX
Nobody got the dbrand? Seems like its built like a tank base on Youtube reviews
