Iphone Duo cases/accessories
vengence_angels
for those who don't like to use adhesive, Speck confirm no adhesive. and it remains fixed on the front, does not come off when opening and closing.
cons is that it picks up fingerprints like crazy and after awhile the phone feels oily.
luckily i put a Popsocket low pro at the back so i can't really feel the fingerprints. :ROFLMAO:
Dkwj14
Using Speck too and loving it while waiting for Caudabe.
Good coverage, both pieces are connected together but as per any clear case finger prints and oil. Need to wipe and maintain it.
Doesn't work with Spigen tg tho on outer display both left side top and bottom edge gets pushed a little, but it seems to be more spigen issue than Speck's.
thenakedshades
do you all know if the Speck front frame can fit a 3D AR screen protector?
Thinking to get if can fit the 3D protector
Dkwj14
Saw istudio got psaj, and red monster frosted but both cost $100 :s22:
Litmuss
Any good, affordable privacy screen protector to recommend for Duo?
Dkwj14
Can't tell for now. Am contemplating of getting ugreen 3D AR Ultra.. But usually 3D don't fit well with cases right I think?
Deceased
Confirmed cannot. Tried already.
But the specks presidio lux fold feels like a good case so I will keep the case and match with SP like Torras
noobzpro
dbrand have centering issue for the usb c port....sold it will re order if they make a new revision
thenakedshades
But the specks presidio lux fold feels like a good case so I will keep the case and match with SP like Torres.
Thanks… I almost pull the trigger to buy, luckily saw your post. Don’t know if can refund from shopee. Sad, my 3D screen protector really good, don’t want to remove
KwayChup
Any fuss free case that can use with TG?
So many different case with different issue I see liao blur
Deceased
I’m on folio rn, pretty good. But is there one that has no front ‘book type’ coverage? Preferably with hinge protection too.
I feel the specks one is not bad but have to find case friendly TG. But abit sad to give up the current ugreen AR TG.
leongws
no one bought casing at singapore retail?
I bought the tempered glass and case locally from spigen Lazada store on September. Case is tough armor pro.
Understand that both having issue and those who bought from Amazon was issue a refund.
Tried it on today and the tempered glass stick perfectly, no issue with edge not sticking. But I noticed shopee spigen tempered glass, the box shows “glastr ez fit pro HD”. For mine the box shows “ glastr ez fit pro” without the HD. Not sure does it make any different. Anyway the tempered glass no no longer available in both lazada and shopee.
The case though really seems to have some issue for the hinge cover. Seems like spigen uses dummy set as dimension measurements and with actual phone, the top and bottom of the hinge cover seems “tight” resulting in the hinge cover not straight when folded.
I also got the Apple case in case the spigen one got issue but looking at the Apple case, seems like it will push the SP if installed.
