Iphone Duo cases/accessories
despair
Need to chime in and say that the official Apple Folio Case is probably one of the WORST official Apple products I have ever used. The magnets on the front panel is so strong that it will lift the front half of the Duo sometimes even when you only want to flip open the folio to use the front screen. Then the magnets on the back half of the case is so crap that the phone can actually get dislodged very easily, and the phone risks falling out. The kickstand only works landscape mode, it is IMPOSSIBLE to use to kickstand in portrait mode. You cannot use the front camera and use the front screen for preview because of the flap. For $179 it’s ridiculous.
tpmmark
Mistermobile seems to offer an “auto fit” protector that can fit most cases
Thanks for the info. Managed to went down and got one for mine duo. And the sales staff also told me they have a casing which just arrived for duo. But she said it’s slightly costly at $50 plus.
disastrous
Did it fit with your existing case?
tpmmark
My case not here yet. I just ordered a simple cheer case from Shopee and am still deciding what to get as a permanent case. Leaning more to those half case. Only for the back of the duo.
Deceased
where you get this? and also the case, is it plastic?
The TG is from redwhitemobile at Bugis. This one suitable for those thick lips front cover like the iPhone Duo case kind cos when I use it on this specks tpu case, there is still space between the glass and the case.
Deceased
Looks too small. Does it have a curved edge or a straight edge? And does it show rainbow effect? Thanks bro
Ya maybe for those rugged cases ba. At least for now I can return the folio case before the 14 days over.
Got slight rainbow effect at the edge due to the gap.
I’m sourcing for others with AR that is not so small and not so big one, probably the Torras or Hoda one.
Akai Ryu
For those on the fence due to all the "gates" or need to cst
fabianlau
Temporary until better ones! So far this TG should be able to fit most cases.
i had the transparent specks case, my wife wanted get same but no stock walk many place.
then die die need casing, so went bugis street found the exact quality just now brand $19.90 near bus stop bugis street
