iPhone X problems faced
swgj86
Need to pay for the pro feature where iPhone battery is shown on Watch?
Here's how I monitor my X's charge status. It shows in real time the charging process and once fully charged, will show 'fully charged' with a plug logo. This app also shows your Apple Watch's battery life and raw data of the watch's battery capacity and voltage, all in real time.
This way, I'll know when to turn off the wireless charger without waking up my phone to see charge process all the time.
discoburg
Sometimes I wanna check in my location in FB, the location I am 'in' is actually kinda far away. Gotta search for the location name instead.
Not sure if you guys play Pokémon Go on iPhone X. I seems to have the problem of GPS Not detecting errors. My iPhone 7 Plus, the game works smoothly.
PSP1_Geek
Inability to update and use phone
I just tried updating to IOS 11.2 using itunes but ended up my phone was bricked :(
Now I can't restore and update and the phone cannot be used at all.
Wondering if I can go down to apple service centre if this persists.
All my data within the phone would be gone :eek:
hard reset doesn't work
I only get a support.apple.com/iphone/restore line on my screen:s11:
Archuke
Official 11.2 havent even out you go update its beta one... Lol
PSP1_Geek
I'm now using my home cpu to do the update.
Based on the itunes 12.7.1, the update prompted to me is 11.2.
If it still doesn't work, think I will need a trip down to apple care service centre.
Wat items apart from the iphone that I will need to bring? Still 1 yr basic warranty right?
renfred89
11.2? You typo twice arh..
Archuke
Apple havent release the signature for 11.2, i think that why it brick your phone
brianlee_sg
Hi just want to check if anyone encounter iPhone X battery percentage indicator stuck no matter how long u charge?
deathst
Nope all good here. Sounds like your charger is barely charging your device. Might be a charger issue.
deathst
You shouldn't be able to update to 11.2 unless you are on the beta program like me. You can download the IPSW file for the iPhone X here
Step #1. Connect your device to computer and launch iTunes.
Step #2. Next, you have to force restart iPhone.
You need to press and quickly release the Volume Up button and then press and quickly release the Volume Down button. In the end, press and hold the Side button until the recovery mode screen appears.
Step #3.
On a Mac, hold down the “Option” key and then click on “Update”
On a Windows PC, hold down “SHIFT” key and then click on “Update”
Step #4.
Select the IPSW file you downloaded and click “Choose”
Let the iOS device update as usual
