iPhone X problems faced
Nevereatrice
Ios 11.2 beta 4 has this bug where the refresh button in safari becomes mixed with the content and u can't press the button to refresh
It happens occasionally not always
xoxolovve
Hi, anyone has issues with unresponsive screen? Couldnt use face id and i couldnt even swipe up to access passcode entering. Would apple be able to replacw a set in this case?
renfred89
its a software glitch. i can't answer and swipe my call to the right, just need to press the side button to turn off screen then press again to turn on.
its not a hardware issue.
mackie8
guys have u encounter a slight animation lag.. when loading the springboard when unlock? is it OS issue?
xoxolovve
Thanks. I called Apple and the guy told me to force restart the phone and it works! Tried to off on the screen before but it didn’t work on mine.
VodkaPear
Anyone encounter this.
For example, for quite some time u did not touch ur phone.
Then u tap on the screen to wake the phone, it will take the screen awhile to light up.
Doesnt occur often through.
But if u keep using ur phone and tap on the screen to wake the phone, it will be instant.
Nwadkh
Anyone encounter notifications still on the screen even after you enter the app? For example WhatsApp? After I access the message, I still see the notification on the screen.
VodkaPear
i think this one is bug. i also noticed it.
not bit of concern for me.
Nwadkh
How long can your iPhone X battery last? When I went to bed it was 24% but I woke up 8hrs later the battery became 15%. I also kept the low battery power on.
deathst
