iPhone X problems faced
nicepal
talking about apple keyboard.
after using iPhone X, I noticed sometimes while typing. seems to have wrongly typed alphabet or space created.
Not sure if was keyboard size is smaller in size so I accidentally typed the neighbouring alphabet or os pick up the wrong letter.
While the spacing not sure was it the keyboard legend up it pick up the spacebar even though I pressed the alphabet before the spacebar..
off course it could also be the cause of my fat fingers.... :)
GGGGGG
The only problem I have with Face ID is when driving, unlocking the phone without my face is troublesome.
Had to adjust the car mount nearer to me and phone facing me.
renfred89
are you supposed to use phone when driving? :D
discoburg
I am able to unlock the X even with my Oakleys on.
Snoweagle
Anyone face GPS issue on their X? Open google maps app and my location is always not where i actually am. Any solution?
Are you indoors or under some shaded area? If out in the open shouldn't have any issue.
nicepal
argentinafa
But lie down on either side of our face on our pillow, how u al unlock? I always fail and got to key in passcode. Unless sit up on bed or stand up on floor inside my pitch dark room, then no prob unlocking
deathst
Generally, your face cannot be obstructed. So if you lie on your back you can unlock it perfectly, on the side is slightly tricky where the pillow cannot block the cheek area. It also cannot have anything in front of your face. as it will throw off the depth map it reads to ensure you are you.
swgj86
i also faced the same issue, generally upright position for face id to unlock.
lying on the side of the bed and unlock, hit & miss.
renfred89
Perhaps you have gone slightly swollen after coming back from seeing the northern lights?
Hahas kidding, I think it’s due to the face mapping issue, maybe you didn’t rotate your face well enough.. I have blanket cover part of my face and it works too..
swgj86
No la. My face same same. Nothing changed. One less reason to check my phone in bed.
nicepal
Maybe you when you are configuring the Face ID that time, you are holding the phone straight at your face looking up straight.
Try reset your FaceID and re-take them with your phone holding lower with your face looking slant downwards instead. Maybe it helps.
dantom04
Do u guys have your iPhone X suddenly goes in a frozen enlarged zoom screen mode... need to hard reset to get it back to normal... anyone ?
