iPhone X problems faced
bryangel86
Guys anyone notice that when u press or put pressure on the back esp. near the apple logo or camera, phone makes a creaking sound? Or when I try to hold phone at both opposite ends, then put a little to no pressure, the phone creaks. Anyone have a similar experience?
renfred89
Woah. You exerting bull force on your phone is it? Day to day use I don’t have the cream sound. As solid. The position of the Apple logo is where the spine of connectors are..
arcturuz
my ipx seems to get hot easily nowadays
even just doing minor stuff like listening to music, the phone will heat up after a while
kashix
The warm feeling will be quite easily felt as the phone case is glass behind. I found it to be warm quite easily if u charge or use it for a while.
faded11
Why is WhatsApp using up so much battery
tjkb230
Always have problem with phone's orientation when in native camera app. The problem surface if I use the app directly from lock screen. Hope Apple resolve this in the next software update.
deathst
Got this phone for about 5 days ago
Do you happen to use Whatsapp Web as well? Cause I can only know of afew reason why Whatsapp will fire up in the background like that. Media downloading, Whatsapp Web and Contact Syncing. If you have Background App refresh on, maybe it is time to turn it off for Whatsapp, you should still get your notification cause the notification service will still run but it will prevent background downloads and network usage thus lowering background usage. Apps have been recently slowly exploiting Background refresh. I keep mine mostly off for 3rd party apps except a select few
SESE75
I just wanted to share if any of the iPhone X owner noticed that
when swiping the 1st page to 2nd or either way after
you exit from the any app, the screen will kind of lag of
shaky, or calling it delay. I tried the some display set
also have the problem. Anyone????
