iPhone X problems faced
deep3lue
nope not restoring anything
tapping is almost instantaneous. same goes for power button, it's just that once in awhile when i press the power button the screen doesn't light up, when i press again it lights up then off (like i pressed twice)
apple pay, lift to wake / tap to wake all disabled since day one :(
I presume you are not using a case?
If you find it bugging you, another way to test is to get several people to test press on the power button on your iPhone X. if they get the same results, then yes you may need to get it checked.
If not, then it could be your finger muscle not use to the firmness of the power button that's all.
angelsNdemonx
hmm with or without case i got the same result....
jordanlah
it's always that once in awhile, knn if go down apple shop also dont know how to show them the issue, must stand there keep spamming until it happens
Just schedule a session with Apple Genius. Now with Apple Store in Orchard, make full use of it.
000kai000
anyone face problem when listening to spotify or music... when you lock the screen... the music also go locked?
currently updated to the latest ios... :(
chiaph
I’m encountering it too. Even with background turn off I still get details my app runs
YouTube iOS App Causing Battery Drain, Overheating Issues for Some Users
anyone encountering this?
Snoweagle
I listen to Spotify everyday commuting to and from work, I still get full control of the music (usually controlled from Apple Watch). Yes, music still plays.
On 11.1.1 though.
raisins
New glitch found, it was raining and I took out my phone and typed in WhatsApp I found this line and my messages all over the place
what i mean by messages all over the place is ..for example the text box as i was typing was appearing at the top of my screen and i couldnt see what im typing.
Thesail61
This is exactly what i had a few days ago and I highlighted here but no-one seem to have the same issue. Anyway, it disappeared as quickly as it appeared. I attributed to Whatapps issue. So far, I cant duplicate the same issue again.
TrueBeliever_jh
if you can reproduce it regularly, you can try to report to whatsapp. it would be very useful for their developers.
Acidblaze
Hi not sure if any of you have this problem.
Every time i was on the call, after a few minutes, i need to key in the numbers on keypad for banking password, the screen just remain black.
i have to either keep tapping the screen or press the side button.
if anyone have some solution please do let me know.
Thanks
discoburg
Like I said its rather intermittent. Sometimes the X doesn't light up and sound the notification tone for the text messages. Quite a few also experienced it.
This is strange. My X will light up the screen to notify me.
When you say "sms", are you referring to iMessage or other chat apps?
