- Jul 14, 2005
Follow your leaks always correctWednesday night you will know.
The 2-pack is full coverage. The single is full coverage as well but with slimmer profile to fit most cases. The 2-pack is all the way to the edges, meaning, some case might be too tight which may cause the TG to be lifted up or create air bubble. Also the 2-pack has oleophobic coating for better fingerprint resistant.
Apple cases usually the front edge is straight up unlike others where the edge is “n” that go above the screen edge to provide additional protection. I have no issue with Apple cases before.Wah tks for the detailed reply cos i also trying to know the diff!.
Like tat, means can the 2-pack TG fit Apple Leather Case? or will Apple Leather case cause the TG to lift up?
It's from tonight 9pm SGT onwardsFollow your leaks always correct![]()
camp liaoIt's from tonight 9pm SGT onwards
see hows the blue color first then i decide what color to keep lol
known to cause scratches when taking the case out as it is right fittinganyone using iphone 12 or earlier, powersupport air jacket? good or bad?
I only use their glass protector before.
Just ordered from japan site:
https://www.pawasapo.co.jp/smaho-iphone-item/case/1184.html x 1
https://www.pawasapo.co.jp/smaho-iphone-item/case/1175.html x 1
actually, I'm very curious..those "plastic clear casing...would scatch "phone surface".....known to cause scratches when taking the case out as it is right fitting
I watch this youtube for air jacket iphone 12...inside say if remove the correct procedure, will not scratch...
Yeah!! My leather wallet with Find My is here. Easy setup, just attached to phone and click few buttons.
No need leak Liao…
No need leak Liao…![]()
No need leak Liao…
No need leak Liao…
How much u got it and is shipping exp?anyone using iphone 12 or earlier, powersupport air jacket? good or bad?
