iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
nagase_4
wah still undecided between green or black for apple leather case.
tmr or thurs, will it be available in all apple shops or those shops selling apple stuff liao?
Think i wanna head down to see see first.
Edit - okie nvm i just ordered the green online liao. haha!
Habrosus
If you are looking at ESR, i'd recommend buying from their Aliexpress store
Made the mistake of buying off their site direct, the price difference.. makes me sad
I noticed Aliexpress has 2 ESR stores, ESR Global and ESR Official, and their prices and stock status are some different. Which one have you bought from, as I'm more concerned with their service quality? :)
discoburg
Case just delivered.
saggice
yes it will be.. I wanna see and feel the real case before committing as well.
it's an expensive case !!
Kusanagi
i bought from the direct site.. where the case costs 4x more than what’s listed in AliExpress
another member shared that they bought from Lazada, if the price diff is not too big maybe it’s better to go with Lazada
HZYiLong
Either one… no need apple brand as long as reputable brand (for safety) and support 20w or higher is boleh
Correct me, first time. As long 20W, any reputable brand is fine to achieve fast charging via Lightning to USB-C cable.
But to achieve 15W MagSafe, the charger needs to be at least or above 9V/2.56A to deliver a maximum of up to 15W peak power.
Op_Valkyrie
Correct - just remember to check this link before hooting. https://support.apple.com/en-sg/HT211829
Anyway I mentioned reputable Brands will indicate the rating on its amp and volt
Habrosus
You mean the ERS Gear dot com site? Ya, I saw their prices too. :(
What I saw are 2 different sellers with ERS in their names, both in Aliexpress. I just realized today that my previous purchase was from one, while my latest order from a different one. Hope this second order comes through smoothly as I'm not exactly comfortable/familiar with Aliexpress. :o
Thanks, anyway. :)
