iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
slowchemical
Icic because shoppe said their stock havent come. you buy for 13 pro or 13 pro max?
I bought 2 cases pro max and they miss out 1. Haiz.... Ya shopee stock delay but if I'm not wrong it's arriving soon. If can wait better buy from shopee.
iamgaara
No. So far I do not have this issue. It is called "popping". It was very common with the iPhone 12 Series Apple cases. I think go back to Apple and get it changed. Should still be within the 14 days period.
Ya I have changed it today. I think it happens frequently when you bend the case at both ends, which happens when it is in my pocket when I squat down. Hopefully the new one is ok if not I may have to consider a new case.
Jirachi
So far, mine is okay. Hope the previous one is just a 1 off.
alan_shearer
choongyangl
I’m using the boost charge 3-in1 with nomad leather case for 13pm, works great
How long does it charge your phone from 0%-100%?
my phone charge from 60% to 70% took about 25min and the phone is warm. Not sure if it is normal.
lahgal
Mous cases looks good, is there any shop bringing in or only online purchase.
Free shipping if you shop above $79, but I only need 1 case which is $59.99
colin27
No need to buy from website.. You can try the mous reseller in lazada.. I have bought 3 cases for my iPhone 13 and prices are lower than from the website.
simcher
never really look at it, usually put it to charge then go to bed.
saggice
using 100w charger, 13% to 50% in 15 mins.
phone gets hot though, wonder if that’s bad for the battery?
Kiddream
I'm using Apple Leather face and the corner pops out slightly when i place it inside my pocket. Is it a defect or it's a design flaw? Today is my last day to return it.
anthonygreenisreal
I feel like you should return it first. Or you can go to Apple store and verify if there is indeed an issue with yours and exchange on the spot.
foosm
Looking for the following for 13pro...anyone can recommend?
  • a safe, reliable and cheap 3rd-party magsafe charger (groupbuy on shopee for apple original still costs $46!!)
  • slim leather case like apple's
thanks!
