iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
PetPet
Moderator
Moderator
Yea I think if anyone wants the patina, they should consider the Nomad.
But it's bit bulky though
Jirachi
Definitely. Since already paid so much for the phone, it deserves a premium case.
Same sentiments!
Is Nomad a good protective case or just for the design?
Also which case is the better one?
Nomad is a very good protective and design case for me.
I have dropped my phone from some heights and a few times flying out of my hand over a distance. Perfect. No damage to the phone or whatsoever.
The front screen bump has quite a gap too. I am using a hydrogel screen protector purely for preventing scratches and it worked perfectly in my case (no pun)
Comparing the iPhone 11 Saddle Brown to the iPhone 12 Saddle Brown.
The iPhone 12 Saddle Brown didn't darken much.
It was way harder to get a patina after like a full year of use.
Whereas, if you have ever owned a iPhone Saddle Brown Case prior to the 12 series you'll notice that within a month of heavy usage, the leather will naturally darken.
But the 12 series? Only small parts of the case turned dark brown.
I personally feel that Apple has increased the amount of coating used on the iPhone 12 series leather cases.
Not sure if it'll be the same case for the 13 series
Thank you for the reply. It seemed to me that Nomad leather would still be my best choice.
I am really a sucker for leather.
Pherenike
How are Apple silicone cases? Still thinking which case to get. Want something minimal but with at least raised lip around the front so that the screen won't touch the surface when lying face down
athenodorus
Apple cases are good..past few years i just need to get 1 apple case (sometimes depend on mood either leather or silicone) and it'll last all the way till my next iphone. not tempted to get multiple cases anymore so it's worth it to me.
GGGGGG
I like the Apple leather cases, been using since iPhone X I think.
discoburg
Ordered the Spigen iPhone 13 Pro Max Case Thin Fit [Upgraded Protection]
nsguru
anyone knows what brand of screen protector to go for pro or pro max?
preferably tempered glass or hydrogel.
Pherenike
Ok thanks, looking at pink pomelo silicone case to go with my pink iphone 13. The colors for leather cases aren't very attractive
Chevalier
I've found the spigen full cover ones are nice. used in on the 12 pro max and the oleophobic coating was nice and smooth
iolanthe
Just wondering if there is a need to buy screen protector for the camera? Upgrading from a xs to 13 pro 😅 bought the Apple silicon case to go with the phone.
PetPet
Moderator
Moderator
Spigen Official on amazon.sg is cheaper than Lazada...
Unfortunately they don’t stock up as fast as the store fronts on Shopee or Lazada.
what amazon carry is the non full screen tempered glass.
