RocketBunny
- Apr 5, 2015
else get those "ziplock" case/pouch kind haha, think decathlon got sell alsoI saw catalyst, but kinda steep because I’m only using it for a trip
or ugreen etc
Otterbox Fre. Very expensive but maybe for daily waterproofing?
I'm waiting for my Shellbox case for the occasional snorkeling.
Thought of getting Diveroid, but Shellbox is available now and about 75% cheaper.
Yup, its for water sports so I will take a look at Chai's recommendation!Is it for water sports?
Can use this type:
https://www.decathlon.sg/p/waterproof-phone-pouch-large-ipx8-itiwit-8362014.html
My girl has one but not this brand. But decathlon stuff are quite ok one. Dimensions seems to be able to fit promax too.
If you talking about diving case then probably can stick to bro @Chai_Latte 's recommendations haha!
ordered the 2022 dji osmo mobile se already, will review if y’all are keen
Received it, build quality wise is decent but don't expect it to be super high end, probably similar to OM4/5 series. DJI Memo app is really good and guide you along if you're new to using Gimbal. The magnetic clamp can be a double edged sword depending on how you view it, it is really strong and holds onto your phone nicely, but the repeated taking it off and on could potentially cause a lot of scuff damage onto the magnetic mechanism on the gimbal.
Stability is pretty good, tilt motion is rather limited especially towards the up region. Like the bros mentioned prior, having an extension rod could be very useful and can expand the way you capture a shot. But to me, I think I can work around it as the price between both, $139 for the SE vs $239 for the OM6 is quite significant.
Activetrack 5.0 is sick, the tracking mechanism is really top-notch that even I myself was impressed by it. Can be really useful for times where you needed an "AI Cameraman". Overall, good purchase.
What brand of TG are you talking about?Caudabe Sheath cannot fit edge to edge screen protector ya?
In general. Looking at hoda or torras.What brand of TG are you talking about?
Should be able to fit...In general. Looking at hoda or torras.
I am using torras with sheath, no issue.Caudabe Sheath cannot fit edge to edge screen protector ya?
Bought the rhinoshield clear magsafe during black friday sales!!!!!! Very solid! It is one solid piece of "CNC" PolyCarbonate (no glue used)!!!
how to tell the real UAG from the fake UAG? saw some UAG cases for 14 series selling cheap. suspect is fake
How much of a price difference you are seeing?
I would suggest getting from authorized distributors or resellers tho.
Don't make fun of my carbon fiber skin leh![]()
