LIN_JOEL
Good news, received and applied the SmartDevil Corning screen protector.
Bad news, it obstructs the display and doesn't adhere properly around corners.
Pros:
  • Mostly seamless look with a Nomad leather case leaving just a slit around. @Rubick's setup with the thicker Nomad rugged case is likely the chef's kiss.
  • Chromatic aberration is gone.
  • Damn good quality for the price.
  • More one-on-one time with iPhone naked.
Con:
  • Idiot-proof applicator doesn't help much. Had to lift the protector to remove a dust spot.
  • Doesn't adhere properly around corners.
  • Obstructs the display just a smidge, but this maybe due to the placement of the screen protector within the applicator.
Received a refund. Will continue to use it, but the next one will be Belkin's Schott. Wasted too much time on bloody glass.
For those interested in scrutinizing their screen protector, visit https://heyeased.weebly.com/
Download and use their double border wallpapers for inspection.
For iPhone 15 Pro Max and 15 Plus: https://heyeased.weebly.com/double-screen-border-14promax.html
For iPhone 15 Pro and 15: https://heyeased.weebly.com/double-screen-border-14pro.html
Good luck, good night and good riddance.
I’m using Smart Devil Schott Glass SP.
This SP is approx 1mm smaller on each side, perhaps to avoid been push by tight fitting case.
The idiot proof tool kit I’m having some issue, when I pull out, it doesn’t peel The back of SP.
so the SP doesn’t not stick and I thought than I received a fault one.
Luckily this time round they include a big piece of sticker and it works well to remove dust.
After numerous tried, I realized it’s the pulling Tab and back peel sticker torn.
So I paste them back and peel off abit and try pulling again and it works.
so far no dust on my SP.
Rubick
The schott glass with my nomad rugged case almost no gap haha. Just nice
v1hypersg
Hi,
How nobody use otter box, specks case ? No good or too expensive ?
I am looking for clear case with raise edges for camera and front screen and also bottom charging hole to be big as I bought few usc c cable with display but the head is big and only spigen case can use
thanks in advance for anyone who can help to share and answer
discoburg
Hi,
Wah it's been a long time since I last heard of speck cases. Last time also have incase cases.
LIN_JOEL
1mm smaller compared to the iPhone? If so, consider the curved bezel on the 15 series, that sounds good.
Yes! The full-size dust removal sticker was so satisfying. Accessory pack was good. Squeegee from Spigen helped.
While appearance may vary, the system is the same and consists of four parts.
  1. The glass screen protector.
  2. The hard plastic applicator which houses the screen protector.
  3. The protective film on the front of screen protector (FRONT).
  4. The protective film with pull-tag on the back of the screen protector (BACK). Expectation: Electrostatic dust removal. Reality: Glorified protective film on the back of screen protector.
Heads up for future folks:
  1. The pull-tag tearing is common and not exclusive to SmartDevil. Simply separate the applicator and iPhone, remove remaining pull-tag/protective film (BACK) and get back to work.
  2. Once done, remember to gently separate the applicator and protective film (FRONT) before removal.
Glad it worked out for you. Any issue with adhesive around the border or border obstructing display?
What do u mean?
So far it fits perfectly with Smart Devil silicon case but I'm getting the UGreen clear case..
Rubick
I don’t think so
Rubick
Two questions.
1. Is the screen protector sticking onto the iPhone completely? Any slit or gap along the border and corners?
I.e. Not enough adhesive/glue along the border.
2. Is the black border on the screen protector blocking any of the screen?
Download and use these double borders wallpapers for inspection. Both borders should be of equal thickness and visibly surround your screen.
E.g. If you see double borders on the left and only 1.5 borders on the right of the screen, it means the black border on the screen protector is blocking the right side of your screen.
Good luck, good night and thank you!
Can see both side borders
LIN_JOEL
Two questions.
no gap, stick well.
I tried using a paper and unable to insert it between the SP and screen.
left side I can see double line clearly but right side the second outer line seems a bit block.
but I tilt my phone abit can see clearly….
I also got the Corning glass but yet to use, is yours same packaging as mine for Corning?
(The one in the right)
Nevereatrice
Anyone can recommend a screen protector for 15 pm that dont cut your thumb when swiping from the edge? Reminds me why i hated screen protectors.
LIN_JOEL
Yes, mine is obstructing the right side of the screen just a smidge too. After these few days, I rather it than distracting chromatic aberration found on borderless screen protector.
No, the box I have is what @kashix has, "康宁玻璃防爆钢化膜 Corning Shatter-proof Tempered Glass Screen Protector". But our applicators are different. In mine I have the following:
  • Screen protector with pull-tag housed in applicator
  • Installation tutorial
  • Accessory pack which includes a wet wipe, a micro-fiber cloth and a small dust-removal sticker
  • Full-size dust-removal sticker
  • Anti-slip mat
An exaggerated example of screen protector not having enough adhesive along the border.
https://forums.macrumors.com/thread...r.2401368/page-35?post=32638053#post-32638053
https://forums.macrumors.com/attachments/torras-issue-png.2296918/
Two examples of screen protector obstructing display:
1. https://forums.macrumors.com/thread...r.2401368/page-21?post=32570731#post-32570731
2. https://forums.macrumors.com/thread...r.2401368/page-26?post=32592999#post-32592999
@cheekeong_7
Morning everyone and have a great weekend.
Mine covering not obvious, I tried another method in that thread, open camera apps the 4 white corner can be seen.
