Eruditeswine
Is the smart devil better than the spigen one?
Both have great packaging and accessories. You get a full-size dust removal sticker with SmartDevil and a handy squeegee with Spigen. Similar installations, same clarity, edge, glide and oleophobic coating.
Spigen is borderless, thinner and more bendy. Sans border and viewing angles, it actual has a larger viewable area than the SmartDevil. However there's a lack of QC. I bought a 2-pack and installed on two iPhones. One was dead-centered on the iPhone, zero chromatic aberration at reasonable viewing angles and not a dust magnet. The other was a dusty rainbow wreck.
It is bonkers how affordable SmartDevil is. if you're worried about the supposed speaker grill, don't be, there's no actual perforation and doesn't even reach the speaker. There are two pain points and all related to the black border. It may lack adhesive along the border. It may not work with your case. But when it does, fuyoh!
So if you have a Spigen with perfect alignment and zero dust, stick with it! Also why I mentioned going with Belkin in the future. Similar coverage, unashamedly have a kha kia do the work for you until it's perfect and that two-year warranty, worth it.
If you wish to try SmartDevil, arm yourself with a translator and carry on. They have patient CSAs and a reasonable refund policy. When communicating with CSA, make sure to differential auto-response and actual response. Shipping should take about a week.
I tried both your methods. The screen protector I can see the double border with my smart devil, the camera app I can see 4 sides the white corner. Mine no blocking?
No blocking, well done kashix.
ragnarok95
Senior Moderator
Senior Moderator
I bought the Spigen 2 piece pack. So far 1st one is okie for me. 2nd one gave away. But i change my glass every few months. I think i will stick to Spigen glass then.
wwh5210
Spigen is borderless, thinner and more bendy. Sans border and viewing angles, it actual has a larger viewable area than the SmartDevil. However there's a lack of QC*. I bought a 2-pack and installed on two iPhones. One was dead-centered on the iPhone, zero chromatic aberration at reasonable viewing angles and not a dust magnet. The other was a dusty rainbow wreck.
It is bonkers how affordable SmartDevil is. if you're worried about the supposed speaker grill, don't be, there's no actual perforation and doesn't even reach the speaker. There are three pain points and all related to the black border. It may obstruct the display. It may lack adhesive along the border. It may not work with your case. But when it does, fuyoh!
So if you have a Spigen with perfect alignment and zero dust, stick with it! I know I would. Also why I mentioned going with Belkin in the future. Similar coverage, unashamedly have a kha kia do the work for you until it's perfect and that two-year warranty, worth it.
*Wah last I check Amazon it was ~3.6/5, today ~4/5 le..
Did u get your SmartDevil from Shopee/Lazada or their China store on T-mall?
LIN_JOEL
good buy but i got a spare anker charger.
I got this liao, also never buy......now waiting for the 200w on sale to hoot and replaced my many many years Anker 100w.
That model old liao, 1 USB C and 4 USB A. The USB C now sometimes also not charging, need to unplug and replug from charger den can work...
Archuke
i also still using the anker 100w with 1usb c and 4 usb a. i got 2 of it somemore. both hoot when it was $50 sales.
the ugreen 200w price is quite ex though.
Eruditeswine
我要买GTR
Hooted this compact powerbank with my CapitaStar STAR$ from Tech House 🤣
Was surprised their store price is cheaper than shopee 🧐
kashix
Yes much better, Spigen borderless but the alignment got problem for mine using the tray, got halo rainbow on 1 side. Smart devil I'm using the Corning glass version, more smooth than Spigen. Spigen got resistant when you swiping. If you know what I mean. Smartdevil ftw!
kashix
Thank you so much! You inspired me to spontaneously slap a new piece on my iPhone. Lo and behold, double borders all around, no obstruction to any part of the display!
Itsy-bitsy lack of adhesive on the corners but what the heck, this is it! Love the display and how the case and screen protector complete each other. Keep safe brother! ✌️
Yours is the same as mine? With pull tab for anti dust or without? Mine is more challenging as without pull tab.
Knightoftheblackrose
Hi,
How nobody use otter box, specks case ? No good or too expensive ?
I am looking for clear case with raise edges for camera and front screen and also bottom charging hole to be big as I bought few usc c cable with display but the head is big and only spigen case can use
thanks in advance for anyone who can help to share and answer
if you are looking for a case with a large bottom charging hole, can refer to this case review.
He also rates and reviews the size of the charging holes at the bottom.
Eruditeswine
Mine has pull-tag. 🤭
Our boxes are the same, but our applicators are different. In mine I have the following:
  • Screen protector with pull-tag housed in applicator
  • Installation tutorial
  • Accessory pack which includes a wet wipe, a micro-fiber cloth and a small dust-removal sticker
  • Full-size dust-removal sticker
  • Anti-slip mat
Splendid work on the screen protector and have a wonderful weekend.
On a separate note, a printed Rhinoshield SolidSuit arrived today. It's an order for family. Took over a week before the shipping notification came in and another day before tracking is reflected on SF-Express. From there, one day from Taiwan to Singapore and another for local delivery. So folks and their loved ones should expect a two-week wait.
Feels great and lightweight. Not as slippery as how Kristin "The Tech Reviewer" described it. Buttons are clicky, responsive and oddly addictive. Buttons and camera ring are replaceable. Large cut-out allows extensive access to the USB-C connector. Pronounced lip. Stupid strong Magsafe.
Print appears high quality. The top and bottom ends on the back are slightly raised to prevent wear on the print. They are taking subtle steps to preserve the print.
Overall, solid case. Family happy, I'm happy. 🤪
