iPhone16/Plus/Pro/Pro Max Accessories Thread
kashix
I bought the Ugreen Corning glass version from TB. Just reached today and I did the application. First piece gaodim. They improved the black border, very slim and I’m able to see the 4 corners in camera mode with almost no blocking. Very happy with it, no dust and very smooth and good coating.
Lustgan
Why u buy with black borders? Isnt no black borders better?
kashix
Black border covers everything, more seamless and won’t trap the dust at the sides. I used before no border one, will have gap at the edges, always have to clean dusts. The border is thin enough without blockage, I’m fine with it.
Limexx
Highly recommend to get the Belkin TG from apple store. Costs $65 but it's worth it as mine breaks every few months.
I claimed with them for a replacement for a tiny crack less than 0.5cm that I can live with, they just sent me a replacement. Not sure how many replacements can be done but if you did 2 or more replacements, it would come to be around $20 per piece.
Lustgan
I recommend u x one termpered glass really solid…
Limexx
I think you are able to say really solid only if the brand allow u to claim warranty when the glass break. It is glass, all will break, just the tolerance how much. I see it's around $33 on shopee or the corning one is $54.
I used smartdevil also corning branded in the end all break and have to stock up a few at home, until I just go for Belkin, upfront cost $65 is quite high but all glass will break and their replacement is fast and good, end up total cost per pcs is lower.
Tbh this Belkin one tolerance quite high, I dropped it a few times expecting it to break but didn't break, maybe just a few scratches.
Lustgan
Ok thats true cause i used x one tempered glass drop a few time no damage at all… 4-5 years alr
perfectlight
Anyone using tietu screen protector from Taobao. Seems like quite a lot of people in china use this. There is one 3d 0.16mm? Thinking of getting it while in china. Anyone else tried before
cloudystar
China has too many brands of iPhone accessories and screen protectors.
Most of them are of good quality. Try and let us know :LOL:
perfectlight
Haha was planning to get. 2 piece + installer for 115rmb agar agar 21dollar. Just wanna check if anyone tried
