iPhone16/Plus/Pro/Pro Max Accessories Thread
jianrong
Is Belkin Ultraglass 2 good? It claim stronger than tempered glass but at a higher cost..
Chevalier
anyone got recommendations for Magsafe stands or pucks with active cooling? gonna place on my bedside or stick on the headboard to charge while i sleep. The heat generated will degrade the battery over time, hence looking at active cooling.
Rubick
I think this time round i will just bite the bullet and get Apple silicon case instead.
But apple cases when drop, got chance the phone will fly out from case right?
Previously I was using their case, low height drop, phone also fly out from their case.
ragnarok95
Senior Moderator
Senior Moderator
Is it? i bought the apple original silion case for my 15pm during offer. Okie le quite tight. I didn't drop la. :s13:
jianrong
This is the atas tempered glass, some ppl swears by it but too ex imo.
This glass can be use by any case? :)
I already bought spigen glastr full coverage plus their back camera len. And spigen liquid crystal. Should have wait abit. ;)
Apple Store clear case have camera control covered. But Apple Store accessories is on it higher price tag.
Backside itchy… Spigen would be wasted. Maybe I should upload it on Carousell since it’s brand new.
Rubick
I think I was using the leather case, slapped it on, second day dropped, the phone fly out of the case.
Haha
koohansen
Some online merchants have returns. I rather use the return service, just create the request and drop it in Pop Station. That's it. Better than dealing in Carouhell lol
Whizdom
any recommendations on transparent casing?
is it normal for transparent casing to turn yellow ?
dyst09
I'm getting the hybrid clear case from Elago. Previously used it for my ip14pm, fits snugly and tight on the phone. quality of the case feels thick and good but ymmv.
only reason i bought it cos the raised edges on both front and camera
Op_Valkyrie
Haha
Depends how you drop, where you drop leh…. You drop from 10 floor, not only phone fly out of the case, the screen also will fly out 🤣
Mine Apple silicone case still tight and solid, no stickiness and it’s expose to direct sunlight due to driving. Not sure those who complained fitting issue or stickiness is due to sweat or frequent taking in and out of case. 🤔
Rubick
less than 1metre height. think I was sitting then drop out from my pocket, the case also fly out haha
Op_Valkyrie
Then might be the angle you dropped, I dropped once while seating on my toilet bowl (also less than 1m), nothing happened to the silicone case or phone, only screen protector cracked, original screen still intact. 😅
