iPhone16/Plus/Pro/Pro Max Accessories Thread
jungon
What you think about Belkin ultra glass 2? Worth the hoot?
Using ugreen TG now, got border and you are right, it’s eating alittle of the screen due to this year iPhone pushing the screen estate to the max.
For me I think worth the hoot. Though it’s not edge to edge it covered until the bezel there
frizee
Ugreen HD ultra clear 2 sets at 50% off leh, means $11+ for 4 pcs (<$3 per pc)
Just wondering how much gap there is though :ROFLMAO:
blues7
used to get apple iphone leather case for first few iphones
then, found some other case that works better?
anyway, for last few iphone, bought those cooling case to use, so far so good, like the texture and grib
iphone 16 pro max cases, few available online now
end up not much choice so bought apple silicone case
expensive $75 but no choice
ragnarok95
Senior Moderator
Senior Moderator
I never tried Ugreen before. I only ordered the Spigen and used the Spigen. So, both of us cannot tell you which one is better. These 2 TG cannot go wrong so just get the one you like.
Kyubi
I bought the cheap ugreen tp and case temporary until my torras combination is here… the ugreen actually looks good
kashix
I’m using the border ugreen now, comparing side by side with my iPhone 15 Pro Max, can tell the black border on this is slimmer on my iPhone 16 Pro Max. Now I think it probably covers a little bit of the screen.
Op_Valkyrie
U encountered the same issue as me… time to go full borderless Liao… I thought will be the same as my ippm 15 hence very early I bought the ippm 16 TG, now I compared the latter screen really very very thin, make sense to go borderless
kashix
I waiting for the bros here to upload picture to see how much gap is the borderless version is then decide if it’s worth the the effort to change.
Op_Valkyrie
I still doing research… but now leaning towards Belkin ultraglass 2.
