iPhone16/Plus/Pro/Pro Max Accessories Thread
kashix
Agree. Somehow or rather this year Ugreen products has been disappointing for me. From their TG to the case, prob they were rushing to launch it before IP 16 was released. Luckily I was able to do a refund via Lazada.
I disagree, am using both their glass and casing, very happy and satisfied for my iPhone 16 Pro Max.
palmtungsten
I have been using non-brand case and glass protector.
No issue when drop and phone still in good condition
this year try Ugreen. Has not tested drop but am confident that it can withstand drop
I have managed to change my mindset to use less than $10 case and tempered glass protector. In the past, only got brand and costs tens of dollars are considered worth and match my new iPhone 😂
used to spend a lot too but it does not make sense anymore if everything is made in China. China made no brand works for me as I see myself that it can withstand drop etc
kashix
I don’t really care price, as long as it’s worth it. Quality of ugreen cases has been very good, I’ve used them for a few generations of iPhones. I was spigen cases diehard supporter but to me the ugreen one is much better and priced even cheaper. No point for me to spend more, only tried their glass this year as my go-to smart devil got some issues with blocking the screen this year, so far very satisfied while on the lookout for better glass that doesn’t block the screen. The ugreen case with cutout not that bad la. Just press in only, no big deal to me and I’m sure everyone will keep to touchscreen control for camera settings.
trd2970
contemplating between nomad modern leather case and traditional leather which is a new release this year with the full leather sides/top/bottom vs TPU. Only downside is the camera control cutout which literally a cut-out vs a hole, so not sure about structural rigidity and shock protection against drops, also it’s very exposed and thus vulnerable to knocks
elvintay07
Suspended
My wife using the Apple silicon case. When I removed it, the edges of the phone looks so clean. Not sure is it the way she use it, or it is the material. Really impressive
frizee
Any Hoda sapphire users? Not sure if I should pull the trigger, or not lol
ragnarok95
Senior Moderator
Senior Moderator
For a "cleaner" look for TPU casing, the uGreen transparent tpu casing is the one to go.
ragnarok95
Senior Moderator
Senior Moderator
Actually my 15PM top corner got a small dent while with the Ugreen tpu casing. No idea how. I dropped my phone once with the casing in AMKhub face down but the TG was okie. So no idea how it got a dent. :s13:
Jirachi
You hooted from shopee? Can see if really got the tray? Thanks hehe and see the border got block the screen?
I will post when it is here
Nice! Please help do comparison with okonz sp too
I do not have the OKONZ one. I merely just based on actual user reviews to determine. OKONZ one is still blocking
Jirachi
Only 1 correct answer.
Your wife use it is clean.
No other answer is correct. Otherwise you will not have a happy life :ROFLMAO:
