IPPT, IPT & RT Questions...
vasilli07
Looks like this is my last year doing ipt liao. Received my last ict call-up. :o
Since here many lao jiao, I wanna ask ar, how come I can jump 234cm for SBJ the week before and then next week can only jump a mere pass 216cm? Overtraining or?
layzibum22
Why I met my PPT but the system say I din meet? Is it because the outpro slip says fail?
vasilli07
U sure every station got meet the ppt mark? If yes, then call ns.sg to check.
And if u have just taken the test, pls wait for 2-3 working days for it to update.
layzibum22
Called NS hotline. The system did not update properly. The operator say on the main system says did not not meet but on another system say met. Took my contact no and would inform tech team to update correctly.
gombak_1980
if booked a ipt lesson but last min cannot attend, (not sick or what), got any penalty or just re-booked again ?
faint.smile
I went for my first IPT lesson and received my ppt band. Subsequently, I did not complete the IPT program and had to go for RT. May I check if I can exit from RT using my PPT band as target?
KuroI-Kaze
Ipt cat test result will only be used if u do not have any past ippt result.
My last last ippt result is silver ... last ippt result is failed around ppt 3 score. I grew fat and unfit and wanted to get a ppt 1 result for my ipt-ippt tml and then book one normal ippt session and pass it.
I nv took ipt b4 and tml is my first ipt session the ipt-ippt. I need to know if tml i go for my 1st ipt session will that cat test result be used and give me ppt 1? Or they will see my previous result? o_o"
j_t_fusion
hey guys, need some help.
I booked ippt for tomorrow 24 Oct, but due to some last minute stuffs, I cant make it anymore. And its too late to cancel via the web, what should I do?
I am not currently attending ant ipt/rt, my window closes next year.
nothing will happen to you... and that session will not be counted.
and there is nothing you can do...
vasilli07
U just ord? If yes, then most likely u start from 0. So just do badly.
But if u did a normal ippt as Nsmen, then don't expect your ppt to be the lowest. Maybe 2-3 if u lucky.
