IPPT, IPT & RT Questions...
KuroI-Kaze
U just ord? If yes, then most likely u start from 0. So just do badly.
But if u did a normal ippt as Nsmen, then don't expect your ppt to be the lowest. Maybe 2-3 if u lucky.
ho seh liao i ord many years le, last year failed ippt they ask me want to convert to new system and take ipt ..
Hi RT :(
Xylitol
My last last ippt result is silver ... last ippt result is failed around ppt 3 score. I grew fat and unfit and wanted to get a ppt 1 result for my ipt-ippt tml and then book one normal ippt session and pass it.
I nv took ipt b4 and tml is my first ipt session the ipt-ippt. I need to know if tml i go for my 1st ipt session will that cat test result be used and give me ppt 1? Or they will see my previous result? o_o"
ppt is based on ur cat test as well as ur past ippt result, dont try to play punk :s13:
juventusfc27
i did 10 sessions of IPT all these while.
www.ns.sg states that i must meet band 2 PPT this year.
my fren say i can just go for 1st session of IPT aka IPPT session and no need book remaining 9 sessions AS LONG AS I CAN meet band 2 in the next session of IPPT i book.
is my fren correct? ty
vasilli07
Yes, after attending 1 ipt session to get your band, u can book an ippt to clear it.
TaZ_MaN
Hi guys, can any kind souls tell me how long does it take for the portal to reflect my IPT results?
I'm on the weight loss programme and I took my weight last monday.
I met the BMI target, but the portal still state that i need to attend RT because i didn't complete my IPT.
Can anybody please share your experience? I went to Maju camp. Thanks in advance.
Raider04
3 work days the maximum.
TaZ_MaN
Thanks, pal.
I called the mindef hotline once i saw your reply.
Btw, I think the hid all the centre direct numbers already.
So, the only way to resolve such cases is through mindef hotline.
Sigh. Anyway, apparently, maju camp didn't key in my weight into the system.
That's why the status has not changed.
Luckily, i made sure my weight is being recorded into the book in the gym.
I was told that the system should be updated by the next day.
So, i find it fishy that it hasn't changed.
Let's see if it gets updated over the next few days.
Thanks.
Tokieda
i took my first ipt last year, cleared my target band 3. my lowest score for ippt was chin up and 2.4km, both 1 point.
so my target band will be 4 automatically for this year regardless of how crap i do for the first ipt-ippt?
vasilli07
Yes. It's always a +1 the following year no matter u can meet your ppt anot.
fi_east
u can't as the system always +1 every year no matter if u meet your ppt anot. :s22:
Wah, like that those who really cant pass ippt very hard.. might as well do rt can get money.. sianzz, who da hell come up with this ridiculous new ipt system.. pls revert back to old ipt system la...
KopRulez
You can always go for the the 20 RT session system if you want. :D
j_t_fusion
old ipt system many ppl will just go thru the motion during the trainings.
the new ipt system forces ppl to really put in effort during the trainings.
SKinny86
Hi, wanna check this is my 1st window for enhanced IPPT system.
Lets say I book my first IPT which is a ippt cat test and I manage to clear requirements for PPT1. Means I no need to go IPT anymore till my next window?
vasilli07
No, u need to get your ppt in the 1st session. U can clear your ipt in 1 session only if u obtain ippt pass. If not, fastest is 2 sessions.
SKinny86
Oh, that means the PPT1,2,3.. is for the first 10 sessions of IPT, if pass the requirements on the 10th session then I no need go the 8 RT sessions. Is that correct?
