IPPT, IPT & RT Questions...
vasilli07
AshleyRiot;39099184[B said:
1) If suay suay I tio mob on the day I supposedly book my IPPT...will they count as defaulted or I failed? :s11: Cos my unit is on some alert thingy...and chances are they will call back as it involves some other units also...
2) If somehow I failed my first attempt, can I book again before my birthday? :s22:
3) If I do not want to book my 2nd year IPPT but I go take it and pass in the upcoming ICT...does it count also? [/B]
1) If it's your 1st time defaulting, then it's ok. If it's your 3rd time, then you will not be allow to book again, aka ippt defaulter. Wait for charge and RT.
2) Yes. Provided it's before your birthday.
3) Yes. If you pass it in ICT, it will also be counted.
vasilli07
hmm vas got something to ask you since u are like an "old bird" here answerin all the quesiton :D
ok my ippt for this window is next week,my bdae fall on OCT,i know i will fail >< so after my bdae on oct,i need to do RT for that window right?after the RT,which i still fail the IPPT at the end of RT,the window OCT2009-SEPT2010 i dont need to attempt IPPT already since i already attempt it on my RT right?so i mus book IPT(i know i wan to go IPT instead) at OCT 2009-SEPT 2010 window or OCT 2010-SEPT 2011 window,pls advice thx
does it mean that once i am eligibl for IPT i doesnt need to worry about RT anymore and can book IPT all the way?and how does IPT work,like in window OCT2010-SEPT 2011 i took my IPT,den next window OCT 2011-SEPT 2012 i can still book for IPT?
No. RT ippt will not be counted as your annual attempt if you failed.
Since you are going to IPT after RT, then you don't need to book any IPPT. It's because the last session of IPT is IPPT. It will be counted as your annual attempt no matter you fail or pass. And yes, no RT after IPPT.
Yup. After OCT2010-SEPT 2011 window closed, you must book again after your OCT 2011-SEPT 2012 window to siam RT. It works like your IPPT window. The only difference is IPT is available in the 1st 9th months of your window.
othniel80
Actually vasilli, now RT IPPT is counted as an annual attempt.
But if you failed, you are still subjected to RT after your window close
if you did not book and pass further attempts.
As for the earlier qns on no. of session of RT you may "skipped".
Theoretically, you may be absent 2x during phase 1 and 3x during phase 2 w/o defaulting the entire RT.
But this comes at a personal risk, FCC usually do not bother if your parent unit "bo chup"
but RT regulars know some units do instruct FCC to report serviceman who skipped
sessions w/o makeups. It depends whether your parent unit wants to take action or not.
Some are known to be very zealous on this. Let me make this clear it is on your own
peril to attempt this.
vasilli07
Ok...long time never go RT liao. Last time, they said not counted. :o
othniel80
:) no prob, trying to help out bros here. They changed it this year only if I not mistaken.
Changes may be taking place again as there are hints and surveys being passed out
during my sessions this year.
I suggest mods could make some info sticky coz the same questions keep popping up
once in a while.
Meridien
ty all for the reply,how im still confuse,when my next windows open,i will take RT first,den after finish RT,when do i book IPT?the next window or the next next window?
vasilli07
i mean this window is my first IPPT attempt after i ORD,so next window open i have to book RT,and after RT,when do i book the IPT?next window or next next window:s12::s12:
RT is to clear your OCT 2009-SEPT 2010 window. So after that, you must book IPT again to clear your OCT 2010-SEPT 2011 window. Hope you understand now. :o
Greenstone
You are required to book a Remedial Training(RT) Schedule.
However, you cannot book now due to the following possible reasons:
1) You may have defaulted your previous RT schedule; or
2) There is no available RT slot within your RT window for booking
Pls contact your NS unit immediately for a RT schedule or further clarification.
:( sianz, stupid SBJ
Ronaldo7
Got a question here. Is the ippt at safra using the same electronic static station at the FCC or using the old school method ?
wingo
just a question...
ok i just failed my ippt last month. My window closes on 16 june. I am required to book RT.
so heres the question.... if i can pass my IPPT now, can I skip the RT ? or do I still need to book RT and go through it.... I am under IHL unit, so i dont think i can call anyone for ICT IPPT... so wat should I do ? any help is appreciated ! THANKS
vasilli07
just a question...
I don't think you can book IPPT now that your window is closed, there is no extension of IPPT window. The only thing they allow you to book is RT. As for IHL anot, it doesn't matter now. All students or personals IHL, all will need to attend RT.
vasilli07
o damn.... ok thx dude ! guess i just have to go through the RT sessions :(
if you can pass your ippt, they will have 1 ippt at the end of phase 1. If you pass, you won't need to go through phase 2 and you are passing for 2 windows(your previous and upcoming)
tiffanydunk
anyone starting IPT on 10th Aug? its a holiday rite, no need to go rite? go on next session?
Hir0shi
Just received a charged letter from MINDEF saying I didn't attempt any IPPT at all during my window. Really scared the hell outta me. Will there be a probability of them having a mistake? Cause I remembered clearly I did not just once but thrice IPPT, so there's no way there isn't any record of it.
I called them up and they asked me to wait for 3 working days for them to check it out. Any one knows of the punishment for first time offence? But I can really confirmed I did my IPPT, my record in ns.sg also shows my booking so should be able to use that as evidence for appeal right?
Sigh... :(
vasilli07
Sigh... :(
Yes...there is a probability of them making a mistake. But 3 times? Abit impossible.
1st time offence is normally only reprimand. Ns.com got your results? Bookings but no results = got book but never take.
