ITX Cases
clay9477
saw this on TB as well, they have design with lighted logos at the front. But its very compact so need to position the fans. I didnt chose this coz i wanted a silent case and dont want fans to be spinning at high speed.
If budget not an issue, can consider Lian Li 150. This case has been used by quite a few tech reviewers.
https://www.lian-li.com/pc-tu150/
zhihao57
Currently using tu150, not bad, but cpu thermals might be slightly on the high side, due to the only input is the front, quite small
gld998
Toaster say toaster.. lol.. my nano s also toaster.. knn. CPU temp hitting 79c on 120mm AIO push pull config.
Sent from Godzillas Pigu using GAGT
hafiz116
This is what makes me worry about the NZXT H1. With our weather here in SG it may not make any sense to get!
zhihao57
True to a certain extend la..
but i believe my temps would drop significantly once i change to tower cooler,
I made a thread regarding my cpu temps recently, Ryzen5 3600, apparently the temps are sort of in the ok range.
gld998
Geek having a preorder now. Thinking of booking one.
A50 PLUS MINI-ITX CASE
https://www.geeekstore.com/shop/a50-plus-mini-itx-case/
networked
RouK3ziLa
Booked A50 PLUS MINI-ITX CASE plus PCIE Riser plus shipping is SGD160. Black out of stock so booked white. :( Hopefully doesnt disappoint.
Self assemble also .. need specific GPU side and power align .. really a big risk.
gld998
looks nice and compact.
I dont quite like electronics with a base stand. If the factory never cut or assemble properly, there will be un balance somewhere.
Pls review later on cpu temp after installation.
Sure. Depends on how fast ezbuy settle for me.. =:p
NightRaven49
Should have use official forwarder. Ezbuy volumetric weight will make your jaw drop plus gst.
official forwarder first 500g already $5, some more cannot ship as many types of things as ezbuy (like batteries) and will still kena gst. also some sellers don't ship overseas, only when u set to china address then say have stock. ezbuy can also siam gst by air below $400/underdeclare.
hg2
Shipped a few case using sgshop, not cheap... easily 40$-60$ after tax...
So, unless the case is very rare and not available from local shop, it's not worth the trouble and time...
ezbuy got the prime subscription with standardize shipping cost for bulk items, but never try before....
taytehni
I paid $19 to ship an itx case using ezbuy, I believe ezbuy's price is actually cheaper than the official forwarder.
Actual Weight 5.54 kg
Volumetric Weight 6.23 kg
Putting it here in case anyone else is keen to do the same and would like to know the rough costs for the shipment.
