ITX Cases
clay9477
official forwarder first 500g already $5, some more cannot ship as many types of things as ezbuy (like batteries) and will still kena gst. also some sellers don't ship overseas, only when u set to china address then say have stock. ezbuy can also siam gst by air below $400/underdeclare.
Not really, batteries related item can be still shipped, just need to source direct route delivery (no consolidation) albeit not many merchants offer this.
TanKianW
Some of my m-itx builds through the years. Some are purpose build NAS(s), firewall + router, desktop PCs.
Bishio
Can u let us know the brand and model for pic 3-5?
Looks good
gld998
Shipped a few case using sgshop, not cheap... easily 40$-60$ after tax...
So, unless the case is very rare and not available from local shop, it's not worth the trouble and time...
ezbuy got the prime subscription with standardize shipping cost for bulk items, but never try before....
Any local shop that bring in Kevcase, Metalfish and SGPC cases? Can recommend? :(
flame2000
I ordered the V2 version, awaiting for it to arrive. Fingers crossed the TG doesn't arrive as broken glass.
I just ordered this too. 2x 120mm top and 2x 120mm bottom fan, hopefully arrives in one piece.
Was considering the NCASE M1 V6.1 but needs pre-order and has no support for top fan. Will lose side fan support if replace with window side panel from W360M.
taytehni
It arrived nicely :) Was impressed by the packaging. Will you be using an AIO? If so do note that the radiator's length must not exceed 277mm i think, I used a deepcool castle and the radiator was 282mm and that blocks the top cover.
none
I used a Fractal Design core 500 case. Its about the same size as the CM Elite 130 however had much better internal organization
Was able to mount a 280mm AIO, 2x3.5 HDD and 2x2.5 HDD and a mini Nvidia GPU. Installed 3x140mm fans which provided a lot of airflow for this ITX case
flame2000
Yes, most likely go for AIO. Thanks for the heads up.
flame2000
gld998
