JH Audio Appreciation Thread
roxanneuniversal
Hmmm JH won't listen to the sound but test with equipment instead.
Meet up la.. Wanted to test the sound track but I'm oversea right now do not have original rox cable with me to connect to my phone.
you don't think jh listened to the universal to make sure it sounds good? test with equipment pointless especially on iem
i only meet up with all the sexy ladies that post here. lots of hotties hehe pretty profile pics.
roxanneuniversal
I rofling here lol.....my conclusions as of now demoing the universal while waiting for my cf to arrive and comparing to my 13s is still the roxannes highs are not well extended....
that's true sounds like audeze lcd3 or warm tube amplifier. benefit is that withotu powerful highs earphone doesn't make your ears tired. it has very excellent resolution and detail though so not muddy.
edit: my old earphone when combined with bright player had too much treble power made me tired after 1 hour. i can listen to these forever. but yes highs could be a little better. maybe shoudl have given us treble dial not bass dial.
stvc11
I don't believe there is manufacturer test the iem one by one simply the don't have the capacity to do that and no way Jerry had the time to do so, do you think his staff able to audit them and do you trust their ear? everything will test with equipment, and judge from there.
roxanneuniversal
I don't believe there is manufacturer test the iem one by one simply the don't have the capacity to do that and no way Jerry had the time to do so, do you think his staff able to audit them? So everything will test with equipment, and judge from there.
with universal you only have to listen test once and then make all others exactly to that tested item's specifications. customs are problem because each is different.
iw ant to get customs but seems like too big of a gamble for money. might gedt something that sounds better than everyone else's might get something that sounds worse. too much gamble.
roxanneuniversal
So how the test is done? Base on what?
what do you mean? jh just plays with universal prototype and modifies it until its perfect for his ears listening constantly then he tells manufacturer to make every universal exactly like that. just like any product probabaly has AutoCad drawing of all measurements and stuffs to make sure they're alls ame.
stvc11
Ouch... You saying prototype. Was thought that you saying production. Btw Universal or not should have only different on fitting as my per my understanding ( I know it had slight different due to tips different). The driver was connected to tube and They are controlling the tube length so regardless of where the driver located they will have the same Sound. Ok I have 2 pair custom rox and I'm very sure they have the same sound signature.
roxanneuniversal
yes going to be pretty close since same insides. why did you buy two custom roxannes?!?!
noobzpro
extended highs and boosted highs is 2 different things...anyways i wont comment further till i receive my set (hopefully in the next few weeks as promised) if it is still the same.....this coming blackfriday 13FP here i come
stvc11
Nope they are not same, driver placement are obviously different. Fit also different, yes done with same impression but obvious different shape. Got 2 because of excess money no where to go lol. Joking.
noobzpro
haha that last sentence xD! jh really dun care bout the first piece?
stvc11
Ya.. Actually the 2nd set went back for refit but get worse so now I'm using the 1st set. Maybe I should get another close mouth impression and ask for reshell.
roxanneuniversal
JH said his measurements show roxanne can extend highs higher than any of his other products so that's not problem.
stvc11
Well... Measurement just a reference. Listening is another thing. I wish it as good as what he say, but to my ear lots not. if not I won't get fitear. You think I really print money meh... Maybe I don't know how to appreciate lo.
noobzpro
measurement using a test tone is one thing....how its represented when music hits the crossover and played on the armatures is another.....
juggakey
Yeah I know. My was done with open jaw.
I see. In this case, perhaps you might need to redo again, maybe change another shop doing the ear impression.
Personally, I tried before digisound and the hearing centre. I have better result with the hearing centre.
noobzpro
you keep making up ******** and changing story because can't keep lies straight.
wow u definitely have some self-esteem issues....go read headfi....afew others agrees too that the details and highs are lacking against jh13....and also for all we know u dont even have a pair of roxannes
