JH Audio Appreciation Thread
roxanneuniversal
i have all the rights to comment as much as i want. :s13: and why so defensive lolz....
well my roxannes sound awesome with the tip i found. yours probably won't unless you're very lucky. you heard all this bad stuff about roxannes and highs and nonsense and you brought them any way because jh makes good product and people get in line begging him to sh*t on them hoping they'll get lucky.
edit: I drew a picture of JH sh*tting on customers but i cna't upload it. it's funny
stvc11
I see. In this case, perhaps you might need to redo again, maybe change another shop doing the ear impression.
Personally, I tried before digisound and the hearing centre. I have better result with the hearing centre.
Ok thx. Maybe worth a try.
weng
since universals are all exactly same i think they would be more likely to have the sound JH "intended" whatever that means. customs are each different and sound different and JH can't even test them because he can't listen to them.
But you did not use stock tips:D
stvc11
When we say bass, sub bass, mid, high, ext high., what the frequency range that refer to?
roxanneuniversal
When you say better, which part you refer do?
everything. sounds like lcd3. biggest improvement is bass which is very tight and controlled like flagship TOTL headphone but not overpowering. spatials amazing doesnt sound like iem at all. i use comply p series slim, with the top 4-5mm cut off and the roxanne inserted deep into my ear. every time i switch to another tip it sounds crappy and i switch back.
edit give me access and i'll upload pic.
weng
you don't think jh listened to the universal to make sure it sounds good? test with equipment pointless especially on iem
i only meet up with all the sexy ladies that post here. lots of hotties hehe pretty profile pics.
Is my profile pic hottie? Wanna meet me? :s13:
weng
extended highs and boosted highs is 2 different things...anyways i wont comment further till i receive my set (hopefully in the next few weeks as promised) if it is still the same.....this coming blackfriday 13FP here i come
haha don't pin your hopes too high. delays and workmanship do not apply to just roxannes. judging from their terrible state now, i think by year end they will still be struggling. :s22:
noobzpro
haha ya lor...relax la....don't need a earphone as of now...
noobzpro
:s13::s13::s13:this guy is superbly entertaining
roxanneuniversal
no need to post. you just google charmaine sheh. :D
did the op use a fake pic too?
heres pics of my tips.
it's the slim versino of this http://www.complyfoam.com/products/p-series/ with the top cut off. you only put on a little bit, not all the way, and then push everything deep into your ear.
sounds night and day better than my other tips. really amazing how much better it sounds this way.
looking at pic i just noticed that my ear canal seems to have bent the tip a little to better align. interesting. i think this might sound good because it provides very deep isolation without using a lot of foam. i dont know just guessing.
Legend2127
Wah... Overnight spawn 3-4 pages...
Stvc11, I sent my jh16 for refit with another set of good fitting tf10 reshell last time, and they redo the whole JH16 for me... Hope it helps for your case...
roxanneuniversal
i still never got a good answer for why stv buys two roxanne customs. that doesn't make any sense considering all other possible purhcases.
