jokerk's worklog
jokerk
Wendler's 531 + "I Ain't Doing Jack S**t" program
Cycle 6 Week 4 OHP Deload week
OHP
35kg x 5
40kg x 5
60kg x 3
70kg x 1
75kg x 1
77.5kg x 1
80kg x 1
85kg x 1 (fail)
60kg x 10 AMRAP
Chest Supported Rows (going for the squeeze and MMC rather than spamming reps)
20kg x 8
25kg x 8
30kg 2 x 8
Bodyweight Dips x 20, 10
Personal Reflections
I felt I could have pushed 85kg a little more. Stuck halfway, held it for a few seconds. I didn't have the mental endurance to finish it up like before. Oh well, live to fight another day.
soteyh
Way to go! Lol, you are achieving pr on your Deload day. The weights look like they are almost at the edge, time to buy more plates!
Jowa__
hey ikhsan, mind giving me some advice on 531 BBB? considering switching to it.. but scared that since each main compound will only be done once a week, not sure if its suited for me as i'd like to think i progress better on a program with more frequency/week; smolovjr
jokerk
hey it's called boring but big for a reason.
Its really boring but imagine doing 5 x 10 of deadlifts at 50-70% 1RM. Very taxing. Similar for other lifts as well.
It depends on what you want to progress on at this stage. 5/3/1 supposedly gets you stronger at all lifts, but progress is slow.
Iirc, polliquin said something like if you want to improve bench stats, you've got to bench at least twice a week. Similar advice was given for squats.
Deadlifts on the other have other specialised programs. I suggest looking at Coan Phillipi's deadlift program if you want to get stronger at deadlifts. I remembered reading elitefts deadlift manual where accessories was focused to improve deadlifts instead of focusing of doing deadlifts more.
Jowa__
yea, that's what im worried about. Currently benching 2x a week, not sure how i'd cope with once a week. :( also not sure should i do deadlifts as i don't want to max out, currently having some form of lower back problem.
jokerk
24/8/2014
Cycle 7 Week 1 Squats
Squats
125 x 5
130 x 5
140 x 1
Super shag from futsal earlier that day. I'm going to try switch some stuff next cycle. (Either floor presses or CGBP as main exercises for bench days, highbar squats for squat days).
jokerk
galapogos
Moderator
Moderator
Not sure whether this applies to deadlifting (since I don't deadlift), but in the 2nd pull of the clean/snatch, one cue is to pull the bar towards your hip. In doing so, you'll engage your lats.
soteyh
Cool thanks guys, will check out the links. I have heard about this cue to pull in towards the hips for deadlifts too
jokerk
29/8/2014
Cycle 7 Week 2 Benchpress
Benchpress
102.5 x 3
107.5 x 3
115 x 2
100kg x 8
Some bodyweight pylos at the park.
Lost upper back tightness. Going to keep it to this load next time. Or probably restart the load at cycle 6 and push for more reps.
