Larkbox - 160ml 4k desktop
evq
Anyone here supported the gmk Indiegogo campaign?
keith
hi,
did anyone tried to run this 24/7 as a simple node / terminal(headless)?
Sambuca78
How is this larkbox vs gmk nucbox?
Technically seems like gmk is better. 6gb vs 8gb. MMC vs SSD. Any comments? Thanks!
yusoffb01
larkbox was first to market so i bought it first. it has both mmc and ssd so you have double storage. if price is the same go for gmk.
yusoffb01
hi,
i used to leave it at work and never switch off for a few weeks to downlooad stuff. more than 5tb download over wifi
Sambuca78
Larkpro was 208 and gmk was 222 during 6.6 Lazada sales but i didn't get any... 😟
U have a point about the double storage, but does mean larkbox has a advantage over gmk?
Thanks!
yusoffb01
Thanks!
$208 is a good price. j4105 pc normally cost $250. anyway i sold away my larkbox and got this instead. having 4 usb ports and 2.5" sata + 2280 m2 storage + gigabit + upgradable wifi is better
watzup_ken
The Larkbox was something I was considering to use as a very low power system for work. However after considering the below points, I decided not to go for it,
1. Only 1 HDMI port
2. Hard to upgrade SSD, i.e. 2242 and I think its limited to SATA3 only
3. Limited USB ports
I like the size, but the above points are deal breakers for me. It is a good form factor for those who don't need a powerful system for light casual usage.
yusoffb01
1. Only 1 HDMI port
the novelty dies quite fast. and if you attach dongles or portable hdd it is not that much different from nuc formfactor
watzup_ken
The attractive thing about the Larkbox is the size, follow by the price. But there are too many limitations for me to consider it. And for me, I wasn't intending to move it around, so the small size doesn't matter to me.
