LG G Pro 2
tainka2405
Screen tint
Hello!!!
Is your screen has pure white colors with a little of bluish tint or a maybe yellow one? Is the white color cold or warm? You can check and see the screen tint if you open the stock lg calculator and look on the top part (the screen where the numbers are written)
Thank you!!!
spyderpiggy
Sorry another question guys :D The pro 2 is 32gb, but why is it that when I view the internal storage, it only shows 24gb as the total capacity. Is it the same for the rest of you?
24gb is for user. The rest is dedicated for the OS and other system stuff.
Uncle_Sams
Just wondering guys,usually how many charges does it take for the battery life to get better?
My past experience is about 5 charges then you will see the difference...
Perhaps the rest experience longer battery life with less than 5 charge cycles?
Uncle_Sams
Uncle ask a dumb question...
Does the output amperage affects how long the phone is being fully charged? Was charging it with my old Samsung charger and it took quite long... Almost 4 hours... The output is 5.2V 1.35A... Our LG charger is 1.8A...
So which is more important? Voltage or Amperage?
Uncle guess it's amperage correct?
PS. You use the LG charger and cable provided or other chargers?
chins
For those of you using SIM card adapters with your phone, take note that the SIM card slot of this phone is extremely tight. Be careful when inserting or removing your SIM card from the slot.
Mine got jammed inside the slot. Used a bit of force and some of the pins inside broke. Extremely bad design. Went down to the service center and was denied warranty. They claim that physical damage not under warranty. Bleahhhhh.....
Uncle_Sams
So how? How much to repair?
lgmw33
FYI, I also use Samsung n Sony chargers planted all over my home . :s13: As long no 'slow charging' appearing at status bar, I am ok,can accept. But if in a hurry n need superfast charge, will use original Pro2 charger.
kelvinti
:D:D:D....For All ages..!
A very solid, firm (non slippery) grip and ultra thin case!
Manufactured and imported from UK!
I love it!
I have an extra "White kitty" case! Anyone wants it, PM me please! :s22:
GreenHorn
Amperage. Use the LG charger AND their cable
GreenHorn
Have to be careful, if stuck best to bring down to service centre...i brought once and they remove my sim card for me...that is before i attempt to pull it out.
Uncle_Sams
I used the Samsung charger and it was super duper slow... Then I Googled it and took out the LG charger and cable... Charging improved to about 2 hours as opposed to the previous 4...
Uncle_Sams
I love it!
I surfed through the website and indeed lots of designs that even Uncle like...
But place the phone on it's back and the casing will be blurred with scratches in no time... Then again it's quite inexpensive to replace...
How much was the shipping?
Uncle_Sams
Besides the LG service center which is bloody far away and back breaking for Uncle, anywhere else to get the original LG charger and cable?
Seen some on Qoo10 but is it original? Also not very cheap...
Disclaimer : Uncle mentality hor always want cheap and good so don't suan Uncle...
kelvinti
Ya! Okay lah! Inexpensive creative case...not too much money wasted.
I ordered it from eBay. It is a free shipping but took 2 weeks to arrive.=:p
lgmw33
Don't quite get you ... you mean can improve Samsung charging time ?
