LG G Pro 2
falcom2002
my pro2 start giving prob
when use 4g,after sometimes connection cut off n need to restart to use back internet.
keep showing some services stop,example clock google playstore etc etc
someitmes blank screen
zzz going 2 year soon...:(
When did the problems started and what have you done
so far trying to find a remedy and still to no avail?
Perhaps other brothers may have encounter the same
problems as yours and could be kind enough to give you
some help to find a solution. :)
I have not come across this since using the phone from
June 2014.
shorty07
Aft my recent prob n doing some reading, quite a few recommended doing a factory reset aft using for some time. Though it not necessarily solves a particular prob, it does eliminate any other prob that can b connected to the software of the phone.
Hisashiburi
Whats the latest firmware for g pro2?
Im still on 4.x since 5.0 has terrible battery issues.
Anyone knows if we are getting android m?
Thanks
falcom2002
Thanks
Ahaa... you haven't gone through #6020 about the latest
update on Pro 2.
You are wise to remain where you are and for all of us
using 5.01 we could not go backward to Kitkat anymore, can we?
Maybe Android MM will come in to your delight if you
want to go for G5 or the current G4. ;)
Hisashiburi
Thank you
Either g5 if it is nice or s7 edge.
update on Pro 2.
falcom2002
Thank you
These two devices will be something that can claim to
be the power house in 2016.
It looks like LG is confident to be the winner because of their
past records in producing innovative ideas in the V10 and the G4,
and continue to have the valuable removable battery feature.
There is no news whether the s7 or the s7 edge will be having
this removable battery feature, but for sure they will have
a larger capacity for the battery.
More exciting news about the challenge that is now going on.
Cast your vote.
Samsung S7 edge vs LG G5
http://www.androidauthority.com/samsung-galaxy-s7-vs-lg-g5-which-are-you-more-excited-about-668224/
George Soros
June 2014.
Reset the phone,some issue still persist..
Example weather apps will stop,email apps will stop ocasionally
Hmmmm maybe the end is near soon :(
falcom2002
Is your original battery still in good condition?
About a month ago, the first original battery that came
with the phone went bloasted (got fat in the centre and cannot
be inserted into the phone).
So everytime I got some hiccup with any apps,
I would uninstall them and then restart the phone.
Everything back to normal again.
Maybe you can try the same procedure, and if it works
then reinstall the apps again and monitor the phone's
performance.
For your info, I also have problems with weather apps,
so I uninstall them after trying out a few. I do not know
about other brothers if they encounter similar issue.
shager
Cast your vote.
60 per cent excited about LG G5.
George Soros
performance.
Ok will try out..
kelvinti
Don't keep the spare batteries unused else they will spoil fast.
I cycle between 3 batteries every 2 weeks. :)
kelvinti
And... I hope there is another flagship in 2016 to replace our Pro 2 besides the LG G5. :)
falcom2002
Well, they may have a reason to delay the release of
the Pro 3 as part of their effort to get customers to stay firmly
on the Pro series. Marketing and strategy thinky...
It could be an upgrade for Pro 2 either by late 2016 or early 2017.
Hisashiburi
Where is the memory card slot?
Is it on top of the sim card slot?
Im running out of memory... have to get memory card.
Thanks!
falcom2002
Thanks!
It is just on top of the sim card slot, better to get a reliable
one instead of the cheap cheap type because of fake ones
from popular brand.
So far the brothers here find that using the local made
Strontium Micro SDXC (Nitro 85MB/s 566X) Class 10 quite
reliable.
I got the 64GB, for now the price should have
dropped below fifty bucks, check the price with few of
the dealers before buying. Enjoy more storage as you can
transfer some apps to the external storage.
falcom2002
Looks things are moving fast, so one wrong move,
the LG Pro series will be down the drain if it cannot match
the next upgrade of Note 5.
It is early to know that Note 6 will be powerful with lots of
Ram and even an increase in size in their screen to 5.8"
So if LG Pro 3 cannot match these features, what is going
to happen is going to be unhealthy. Now it is a bit of thinking
and change to be made and implemented accordingly.
Lets hope LG don't get themselves caught with the Pro 3,
as the current V10 has lots of approval from consumers.
kelvinti
Anyway, aren't we expecting the arrival of Android 6.0 soon on our Pro 2? :(
Both the LG G3 and LG G4 had gotten it before CNY wor! :s22:
falcom2002
LG knows better if the MMellow 6.0 Android is suitable for
Pro 2 fluid functionality. I am happy with the current setup
of Lollipop.
Hopefully by the time Pro 3 is ready to be released, Android 6.0
would have found its hay day sorting out its early friction.
Also LG got to find out whether there will be any issue with
the new design battery to work with 820 SD along with MM. :eek::s11:
