LG G Pro 2
xiaovanz
One of the best in the market even for night shots in auto mode. There are settings to adjust to even make it better for night shots. :)
Great! macro shots?
Sorry many questions cos I never use LG phones before.
So i need to know more. :o
kelvinti
Battery charging of Pro 2 is one of the fastert in mobile phone.
As for battery life, you have got to compare it bewtwen Android phones with almost the same screen size! ;).
It is better than Note 3 and pretty good for such big screen phone. One cannot camplain anymore ba. ;)
If you expect a super duper battery life, then get a smaller screen phone likes G2.
kelvinti
There isn't any macro mode but the macro effect is very good by manual adjusting the focus between near object and background.
You can take very good macro shot with Pro 2! It is better than my previous Note 3. :)
zjjx1977
For video call. Install Tango from PlaySore.
That's the most popular video call app on Android. ;)
Most Android users have it installed for video call. ;)
Note3 can video w/o installed apps. Seems lg no. Help friend ask, thx
jazzman80
1) Is the battery life okay?
average each % lasts 6 mins of screen time, on 4G, brightness 30%, sync off and stuffs.
mine once hit 5hrs at 50%,100% 4G network.
that's including some usage on whatsapp too, surf Facebook on browser instead.
Facebook standalone has too many wakelocks.
2) Will it auto wake when there is SMS or whatsapp msg?
can configure. if you want minimal wakelock, install 'smart data switch pro'.
3) Is it Made in Korea?
yes but the battery.
4) How long does it take for full charge?
just leave it there unused, not more than 2hrs.
athenodorus
seems like there is but i don't see it in my phone. Perhaps only Korean variant have?
Persie
To be frank, if there isn't any Pro 2. I'm sticking to Note 3 for sure because Note 3 is still a top notch phone. ;)
However, I rarely use the S Pen. ;)
If i didnt come into this thread too often, I will also stick to my note 3 until G3 is out!!!
ceejay94
Been using this to my phone going into my 3rd week. Definitely an awesome screen coming from a previous 5S user.
However, any bros have trouble removing the sim card? I had a note 3 earlier and while it also has the same irritable micro sd tray above sim tray design, till date im still not able to get my sim out... Any tips people? ):
kelvinti
Easy done for me leh!:s22:
You cannot press it hard. You must slide it out gentlely ...:s8:
You, too rough? =:p
ceejay94
You, too rough? =:p
Serious? Ughh maybe its due to the fact im using a micro sim adapter. It feels so slippery..
Wished the sim slot was spring loaded. ):
kelvinti
No choice! It is designed this way since they placed the sim and sd card tray on top of each other!:vijayadmin:
kelvinti
How much is it if Im buying without plan?
Reputable street retail shops = $690-$710 depending on shops. There are about 10 shops that almost most of us bought it from! :)
Telco outlet = $838.
**No one here buy from telco shops due to the obvious since the phone that the street shops sell is the same as the telcos sell..;)
mun
read thru the thread lor..hardly see any major issues with this phone and quite a few of us hopped to this phone from note 3.
long run i think note 3 will still fetch higher value but i prefer LG's UI and design, esp the knock code.
service center is ok cos not many LG users compared to other brands, hence shorter waiting time.
However, only 1 center which people in the east may find it a hassle to go all the way to the west to repair.
I hope I wouldnt have to travel to lg service centre at all as the place is not very convenient cos I stay north.
