LG G Pro 2
kelvinti
Be positive!
Don't worry and don't think about the service or where the hell or heaven the service center is located.
You will buy a good phone without any defect 99% of the time. ;)
jazzman80
However, any bros have trouble removing the sim card? I had a note 3 earlier and while it also has the same irritable micro sd tray above sim tray design, till date im still not able to get my sim out... Any tips people? ):
don't ever force it out or else, the prongs gonna broke.
and you have to bring it down to a shop somewhere in woodland for repairing.
though it cost not as much as what LG offers, just be careful not to use force.
kelvinti
One more thing.
If you ever worried that Pro 2 is too big! Think again!
Comparing it to Note 3 which is a bit shorter than Pro 2, I can tell you that Pro 2 is much more comfortable and easier to hold and operate with one hand than Note 3 due to Pro 2's curvy design especially the edges. ;)
In addition, the configurable keys in the OSB adds to the easy operation than the fixed capacitive button of Note 3. :)
For example, I can arrange my BACK key to be in the middle of the OSB bar so that it is easy for me to reach it with either hand /finger than the fixed BACK key on a capacitive botton which is either fixed on the left or right corner.
Trust me or trust us here! ;)
mun
Battery charging of Pro 2 is one of the fastert in mobile phone.
As for battery life, you have got to compare it bewtwen Android phones with almost the same screen size! ;).
It is better than Note 3 and pretty good for such big screen phone. One cannot camplain anymore ba. ;)
If you expect a super duper battery life, then get a smaller screen phone likes G2.
For charging, I am using note3 charger to charge all my family phones (gpro2/note3/nexus5). It sure charge up the phones to full quite fast cos of high capacity - from low batt to full less than an hour :D
kelvinti
Yeah! Using the supplied charger, it can reach 100% from 20% in less than 1 hour. It is amazingly fast and furious.:)
mun
I prefer OSB as I have been using it since nexus4 till now. Reason I move away from iPhone & Samsung phone is because of the capacitive button as I always feel anything that is movable sure wouldn't last long. All my laptops and desktop are also using SSD instead of normal HDD cos of the same reason :)
ceejay94
Alright. No force.. guess i will have to try other methods then. Pretty sure the fault is with the damn adapter for being so slippery.
Anyway, thanks for the advice people. :)
Chipero
I used my S2 charger on my Gpro2 and its also damn fast. Cool :)
benzene
My case arrive today.... i love the case and my G pro 2
kelvinti
Just gotten the black one and passed the white one to my wife...she is loving it, and I am happy too cos can try different colors! Haha!
Nice! :) Happy and loving couple! :s22: Can try different "pattern" too besides color!:s13:
