M1 wifi calling
lohsenglte
Negative. I have Wifi Call on my S8/+ on M1, bundled Talktime will still be deducted (as mentioned), if not, i also check my bundled talktime deducted too. if im not wrong it is just VoIP thingy...
WiFi Calling is enabled on Galaxy S8/+ as well?
manofsorrows
It will be great if the telcos allows calling back to a sg number overseas while using wifi calling. Similar to what u mobile in Malaysia did.
bencheongcm
S7, S8, S9 have wifi calling? I don't see the option?
omelet
Does wifi calling on StarHub even work? So far only seen the Wi-fi word beside Starhub on first day after I turned on.
I slot in my Singtel Sim immediately get Wi-if calling all the time as Long connected to Wi-if.
renfred89
When you're using the starhub sim card, make sure the wifi callimg is turned on.
Singtel carrier settings might have enabled WiFi calling by default by starhub don't.
I know m1 don't enable by default when the carrier settings are updated.
MyNameIsNas
Call will still be deducted as per normal call time.. what is key is call quality when reception is not at its best.
omelet
Yes, it has been on since I turned it on. I have only ever seen the Wi-fi word for 2 times in the first day. Subsequently, never seen it anymore, I checked the wi-fi calling it is still on though...that is why I asked.
Singtel wasn’t on by default btw
Nemesismaster
Don’t get the point when u switch to wifi for better quality voice calls when Watsapp voice call also does the same thing moreover Watsapp is free
coloumbiaGames
Lol. Mine doesn't even show since day 1. Can't be bothered. :s13:
manofsorrows
Was at mcdonalds earlier and my wifi hooked into wireless@sgx. Cui ! Call quality like a cui, I switch off wifi and its back to normal.
Zakhri32
This is very convenient for me, the place I work at has horrible M1 reception and people can’t call me, haven’t really fully utilise it though so don’t know about the call quality.
lohsenglte
Do tell us how the call quality is and see if you can receive SMS too?
Tested on iPhone 6s Plus, as long as you're inside the wifi coverage, things work as usual. Not sure if have HD Voice or not though, afterall iOS doesn't show any indicator for that.
M1 only implemented Voice for IMS, so cannot receive / send SMS over M1 WiFi Calling. Have to connect to cellular network before you can do so.
manofsorrows
But still calling back home from overseas is still considered an overseas call unlike what u mobile does.
manofsorrows
Good question. I am not travelling anytime soon, maybe someone can try and provide FR ?
