Macbook Pro 13" 2020
amazingneil
I am actually thinking of buying the macbook 13 2020. However, when i search online, there is alot of comparison with dell xps 13 2020. So i am actually really confused. I want to use for university and beyond
-Grift-
Depends on which OS you want to use? :s22:
hereiam7788
macbook pro FTW. you can run bootcamp on macbook pro even u want to use windows. and you can switch back to macOS when you need to.
best of both worlds.
comcrepe
best to go with whatever your budget allows. no need to think about using it beyond university cos once you get that first pay cheque, you will think changing.
robertgl
Has anyone purchased a hard shell for your 13" macbook pro laptop? Been asking shops and all don't have stock.
MaoZeDuo
Challenger selling the 2019 version for $2259,
MacBook Pro 13-inch (Grey) 2.8GHZ 8thG Touch Bar Quad-Core (Intel i7, 16GB, 1TB SSD Storage)
Any advise between this vs the 2020 model? Using for light photo editing.
ksksksks
Premium Clear Case for MacBook Pro (13, 15, 16 inch), MacBook Air (11.1, 13, 13.3 inch), Macbook Retina (12 inch) - Plastic Hard Shell Cover, Compatible from Oldest to Newest MacBook, With/Without Touch Bar, Transparent Clear https://s.lazada.sg/s.IQZh
Got it from here. Choose the ‘MacBook Pro 13 2020’ option
Thanks. Looks good. Tried searching Lazada and it states not compatible with 2020 model. Where did you buy it from.
robertgl
Anyone bought AppleCare+ for your MacBook Pro? Is it worth?
Yes I did. Really useful in the event of an issue. My touchpad failed in my previous laptop when it was close to 3 years. It was changed without having pay anything.
arvinsim
Always buy Applecare for Macbooks. It always pays off.
Just the other day, Apple technician found out that my laptop has 2 dead battery cells. Since I was on Applecare, I was able to get the battery replaced for free.
Pampers
My 2018 MBP 13 has severe battery bloat, now I think a replacement will cost me dearly
