Macbook Pro 13" 2020
2wheels2smile
Hi Apple macbook/ipad Pro users,
Can I check if let say I crafted a word document in windows pc/laptop, when I open it in word in Apple macbook/iPad Pro, will it open up in exactly the same format and able to read all the symbols used?
Cheers!
tec_geek
Cheers!
For most of the texts and symbols, yes. Unless you are using custom fonts (or symbols).
If you’re using custom fonts, you have to install on the devices you’re going to open the word document with.
frozened
From what I understand, the 10th gen Intel CPU in the 13 inch MBP is the i5-1038NG7. It seems that the 28W TDP isn’t fully utilised because the 13 inch MBP’s thermals aren’t that good. Meaning to say the boosted clock speeds would likely not be realised. A quick google search showed an article about this based on early benchmarks. Is it then worth the premium over the 8th gen CPU in the base model?
Context: I’m currently on the 2015 15” inch MBP with the i7-4870HQ CPU (no discrete graphics chip) and am thinking of upgrading to a 13 inch MBP.
I have the i5 MBP and i7 MBA 2020. Wanted to test out which was better before returning/selling either one.
The 10th gen difference vs 8th gen is only faster graphics processing and slightly higher multi core performance. Which to me is negligible because day to day use you most likely only utilise single core.
Unless u are hard up about the lack or ports then get the 10th gen. If not the 8th gen with 2 ports is more than enough.
punggolkid
I will most likely go with a 10th gen processor due to the better integrated graphics. Comparing the i7-1060N7 on the MBA and i5-1038NG7 on the MBP, the benchmarks seem to suggest what you have described (I.e. similar single core performance, better multi core performance). But at 512GB SSD / 16GB RAM configuration, the MBP cost $300 more and has 2 additional USB C ports.
My consideration would be: does the MBP have longer battery life and better screen? Weight wise seems similar 1.27kg vs 1.4kg. I don’t do any video editing, but I do run boot camp for windows 10 occasionally and game on it (lowest settings and 720p of course).
fateless
I looking at 13 mpb. Is 256 ssd upgradable in the future? The additional $300 to increase to 512gb is a bit too much.
I Mainly use it for coding and my wife would bootcamp to windows
Chevalier
Momentumm
I second what Chevalier and adiboy says. I just received my refurbished 16" and I seriously cannot tell apart between a brand new set and this. Tried to find some scuffs or visible faults by peering into the ports even but everything looks and smells brand new. I saved a bit of money and guys.. The speakers for the 16" is insanely good! I don't think there's any laptop that can beat the sound!
I would really suggest to re-consider if you can pay a little more. Refurbished sets seems to come with brand new cables and charger and battery. Didn't know that they will change the outershell too.
Shutterfly
I think we should have 16" MBP thread! Haha.
frozened
Then it to question do you bring it around Everyday. To me the 100g is negligible. But I can guarantee the MBA lasts longer day to day.
Performance wise MBP will outclass MBA by 60% due to better thermals and MBA at the fly is hot when running cpu intensive stuff like.
szeli
i bought the base mbp 2020. may i know how long the battery is expected to last without charging? i saw a separate thread about battery issues. mine drop like 1% every 3-5 mins by watching youtube videos and surfing of website. is that normal?
Chrome or Safari? 5mins/1% seems quite reasonable
c0ke123
So most prob i will go for MBP base model, thinking if i should just pony up $500 and get the 10th gen and be happy for years. Or just stick to the MBP base model as a stop gap solution till next year when the new 14inch mini led mbp launches. :s11:
Raise another few hundreds also no issue since isheeps r rich
Sent from Rem Best Grill using GAGT
jeffprobst
is boot camp stable? my last was mbp in 2010 while i was a student. currently using wins but seems like the laptop gonna die soon. now that i only using it to surf the internet and do design work once in a while, was thinking of getting back to macOS wagon.
