Mari Credit Card
subprimelive
For the physical maribank credit card, do you all sign on the back of the card upon receiving the card? I intend to use the card overseas
subprimelive
Thanks. The Mari card also don't have the credit card numbers and expiry on it.not sure if it is a new security feature
Panerex
The foreign currency spend 3% FX rebate + 1.5% cashback extended till Dec 2025. However for those who use the card to do Top ups for any wallets or use for excluded MCCz, DO NOT do this because you won't even get the 3% cashback to offset the FX fees, the Trust card is better for those use case.
Good news.
Can continue to put my Trust Cashback one side, except to use it to top up TNG
sibeiTrolled
Numberless card. You can search this up, though it doesn't prevent online brute force attack.
Never signed any cc since I gotten my first. It is not even a secure way of validation and no one really checks it. Just use it contactless or if you have to, swipe or slot in with pin verification.
Just make sure the overseas setting is turned on else you will receive maribank notification about failed transaction
subprimelive
I did not receive any pin number in the mail , when I received the physical maribank card. When you use this card overseas and you need to swipe/slot in, need to enter pin ?
sibeiTrolled
Your maribank pin.
Edit - At the very least, please explore the app since you already have it.
I never had to cause all contactless works.
I am saying swipe or slot in is your alternative if contactless dosen't work
lasnoblur
Hi all, I want to add the excluded MCC is similar to those typically applied for sg. This includes sch, government services, etc. check maribank credit card tnc for full list. I just made a 4 digit post office payment in JB. I thought that it is ok but it is not. I made a mistake. Do not be like me.
sglandscape
Lesson learnt 😂 learned it also when I checked, good thing tested with a small amount first
wutawa
iras, utilities no rebate
starhub has rebate
S&cc cannot use maribank giro and cc :confused:
~sabaisabai~
is the exchange rate good?
can use in jb?
