Meizu M1 Note
gab_chia
Just got a set at Komtar JBCC. The salesperson said all colours are available for now, however the free screen protector and case is OOS. They will let you know when it's available and you have to go back and collect.
Rickosw
what is this app that keep crashing?
hi guys,
does anyone know what this is app / where is it found, so i can uninstall it / least force stop it?
ps: i have a export set/unlocked, china-unicom MX4 Pro set.
other than this "stopped working" message, i get a few other apps that also stopped working once every other day as well, eg keyboard (swiftkey, facebook) - does anyone face this same problem?
what do you think it is root cause? need Lollipop software update?
Rickosw
Software update fix many bugs
Meizu software still needs lots of polish ... cant believe so much bugs inside ... but least they are doing something better than nothing ...
https://www.facebook.com/meizumx.malaysia
MEIZU Malaysia
3 hrs · Edited ·
NEW FLYME FOR MX4 INTERNATIONAL RELEASED
http://www.flyme.cn/en/firmwarelist?modelId=14&type=1
Flyme OS 4.2.2.2I
Highlight:
This software update including enhancements and improvements for your device.
Changelog:
System
Added Turkish to the system;
Fixed the disappearing bottom bar issue after disabled "Intelligently hide Smartbar";
Phone
Fixed the issue of unable to end calls when hold the earphone controlling panel;
Fixed the problem when return to Home Screen after a call and check task manager, the screen display would be abnormal;
Cloud service
Fixed the problem of mistakenly delete contacts due to synchronization failure;
Lock screen
Fixed the function icon mismatch issue when slide the screen to left side to activate Camera under locked screen;
Gallery
Fixed the issue when move or copy some pictures to a new folder, the folder list is incomplete and some folders cannot be displayed;
Fixed the issue when slide through thumbnails quickly and tap return key, a bug would be reported;
Music
Fixed the issue which users cannot add music to favorite when using Music plug-in in the pull-down notification bar;
Browser
Fixed the memory leak bug occurred in Browser;
Fixed the bug that when sharing a website, long press an icon in sharing interface and the Brower would crash;
Painter
Fixed the eraser bug under certain circumstances;
Clock
Fixed the bug related to the Timer in which after switch and finish another step, the previous step would be run abnormally;
Calculator
Optimized the algorithm for the four operations.
Tips:
Downloading via mobile networks may incur additional charges. If possible, please download via Wi-Fi network.
To avoid loss of data & if required, please perform Flyme or relevant backups before upgrading
To avoid bricking the phone, do not turn off or reboot the device while upgrading
berber
Meizu regularly releases firmware upgrades/fixes to their products and has a good track record of supporting even their old devices (like the MX2, a 2012 model which is confirmed to be receiving lollipop soon) :)
Rickosw
yeah, i know, apparently they have one "beta version ROM" ... i really hesitate to try ... scare later brick, then i really HONG GAN
http://bbs.flyme.cn/thread-210424-1-1.html
ps: have you download this yet?
in the meantime, hope lollipop come fast, and fix up some of my software bug
geckoSG
Just got my phone today. Immediate put on my anti blue light screen protector n casing. Phone feels very light. Fly OS is simplify but not as good as I feel it could be. Apps icon r doubled on desktop. I have 2 whatapps icon when installed. Many widgets r not available. Battery life quite decent so far. Tomorrow test more. Now 8hr charging cycle
geckoSG
my flyme OS version 4.2.0.3, android 4.4.4, malaysia model. btw, while doing the DnD feature adding whitelist, i cant seems to key to find contact, need to scroll to add contact. have anyone tried and can do search?
Sausage
are there any local sellers? I don't see this phone listed.
Rickosw
officially No SG meizu dealer ... i also dun know why Meizu skip SG and went to malaysia instead ....
if you die die really want warranty, then go JB - JBCC - level 2. Authorized dealer
but you can try Adix82 (give him a call first) - he will be selling PRC Set (not Malaysia set)
- alternatively you can try your luck at Liang Court - AudioHouse - they sell quite a few PRC brands - but i'm not sure if they got carry this model ... can call and check as well
geckoSG
u can buy online on the malaysia estore. free shipping if u r not in hurry. else pay RM50 or RM60 for express shipping to SG.
Sausage
i am eyeing the one on lazada, 32gb at $345 by Topbeeth, got $15 off if buying today.
but no info on what set this is, malaysia or china. Anyone bought? Also is it in english or chinese?
napster79
Actually $15 off lazada not really attractive. Sometimes they have $50 off min $300 promo. If not in the hurry maybe you can wait.
I supposed lazada sets were from china. I would suggest getting from JB. At least there will be 1 year warranty and freebies. :D
Me also eyeing 1 for myself..:s13:
edmund_gan
You may as well get the set from Adix at $320 for 32gb version.. Compared to lazada.. Just need to check with Adix for stock
Sausage
did you all also get a case and screen protector from adix? They don't list any.
Rickosw
nah, i didnt buy from him - got my tampered glass n case directly from mainland, but i did see Adix selling very simple case n SP for meizu products ....
