Microsoft's Surface
quekky
there's the pen holder that comes with the keyboard, where do you all stick it?
I stick on the keyboard but less then 1 week came off liao, think is coz the keyboard too fur
Fallingrain
Stick on the keyboard. Mine still ok maybe because I never use it. I using 3rd party pen so can't fit into the holder
Sinkie
New sp 3 users here, can check can I install office2007 that I installed on my pc in it ma?
pandazilla
i think the "fur" on the underside of the KB is more furry than the kb side. i stick on the kb side. wanted to stick on device itself but not sure where haha.
did not try office 07. should work right? it is a normal desktop? unless you're worried about win8.1 compatability
knightshaz
High Honorary Member
older software will have more problems with compatibility, old games run fine though, playing all the C&C games on my SP3
jjaks
Just bought 64GB SP3 today from Harvey Norman. Free keyboard + free laptop case coz paid with POSB cc.
rarenick
No problem installing office 2007 with Windows 8.1 but 2007 is quite old and does not support docx formatting. Alignments will run.
Sent from a smartphone using GAGT
eyz
is there any 3rd party web browser that is as smooth as Win 8 Internet Explorer?
tried chrome, but the scrolling is laggy.
Viari_
Todays Ultra book is as small and comparable to SP3. Also in term of price. So why SP3 especially if you add on the type cover.
Cause you can take out the keyboard and chill on the sofa without the it being in the way :D
Not to mention it might also get hot :s22:
eyz
does ultra book come with touchscreen?
